Autodesk Factory Design Suite
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Connector should be a point of the edge, can't use user defined point?
- Highlight
- Email to a Friend
- Report Inappropriate Content
Dear All,
We are testing the connector definition. we meet problem that the conveyor's height can't automatically change if the connector isn't the a point of the edge.
Please get the attachment. for ShockConveyor.ipt, we defined 2 connector of the right side, one is a midpoint of a edge(connector4), the other is intersect point of three plane(connector5). the connector4 work correctly but failed with connector5.
What wrong with it?it's the limited of the connector point?
My Best Regards,
Rick
Re: Connector should be a point of the edge, can't use user defined point?
- Highlight
- Email to a Friend
Hi Rick,
Yes, that is the limitation. The connector 5 only propagate the parameter "RightHeight'. Currently, the connector class didn't allow defining the expresion, say "RightHeight+300mm".
-Xuesong
- Highlight
- Email to a Friend
Hi Rick,
I am writing a ilogic code to control the RightHeight based on which Connector is consumed.
If (RightHeight <> iProperties.Value("Custom", "RightHeight_backup")) Then
RightHeight1= RightHeight+300 mm
ParaChange = 0
Else If (RightHeight1 <> iProperties.Value("Custom", "RightHeight1_backup")) Then
RightHeight = RightHeight1 -300 mm
iProperties.Value("Custom", "RightHeight_backup") = RightHeight
iProperties.Value("Custom", "RightHeight1_backup") = RightHeight1
Also,I added new parameter RightHeight1 and set as key (must be set as key) in model and update the connector class .
- Highlight
- Email to a Friend
Thanks, Xuesong, It's work very well!
