Autodesk Factory Design Suite General
Valued Mentor
Logos_Atum
Message 1 of 5 (243 Views)
Connector Classes/ Verbindungsklasseneigenschaften
243 Views, 4 Replies
07-10-2012 01:34 AM
Hello there,
I got a question concerning connectorclasses. I created an asset which i want to match height and width with another Asset. Yet i failed to locate the*.connectorclass file for my user library assets. Can you help me out to locate them and give a small example of how to do the job right?
Hallo da,
ich habe eine Frage die Verbindungsklasseneigenschaften betreffend. Ich habe ein Benutzer Asset kreiert und möchte das dieses Höhe und Breite an die eines anderen Assets anpasst. Ich hatte keinen Erfolg damit die Datei *.connectorclass im User Asset Verzeichnis zu finden. Wo finde ich diese Dateien für meine User Bibliothek Assets? Könnt Ihr mir helfen diese zu finden und ein kleines Beispiel geben wie ich den Job richtig machen kann?
Hp workstation - Xeon 3550 - 12 Gb Ram - Quadro 2000 - Windows 7 - Factory Design Suite 2013 trial (Full licence is to arrive soon)
- 2500K @ 4.2Ghz- 8GB - Radeon7970 -
- Xeon 1230V2 @ stock Ghz- 32GB - Quadro 2000 -
- 2x Xeon 2670V2 - 64GB - W7000 -
- Factory Design Suite Premium Subscription-
Employee
Message 2 of 5 (226 Views)
Re: Connector Classes/ Verbindungsklasseneigenschaften
07-10-2012 06:46 PM in reply to: Logos_Atum
The .connectorclass file need to be located at the connectorClass folder in the system factory asset library path. For example at C:\ProgramData\Autodesk\Factory Design Suite 2013\FactoryLibrary\ConnectorClasses
The attached is the sample how to define the connectorclss. So please copy the.connectorclass file to the  connectorClass folder in the system factory asset library path and copy the two folder which including the sample asset to your user factory asset library.
-Xuesong
Valued Mentor
Logos_Atum
Message 3 of 5 (221 Views)
07-10-2012 11:55 PM in reply to: Logos_Atum
Thank you very much.
I will work the info as soon as possible (some more important work happened to appear) and report, if necessary, anything i come across.
Kind regards
Daniel Thyringer
Valued Mentor
Logos_Atum
Message 4 of 5 (213 Views)
07-12-2012 12:28 AM in reply to: Logos_Atum
Thanks to your advice and the sample file the Problem is solved.
Thank you very much and carry on the good work.
Best wishes
Daniel Thyringer
Employee
Message 5 of 5 (207 Views)
07-12-2012 01:54 AM in reply to: Logos_Atum
You are welcome. Please let us know if you have any comments on the FDS solution.
-Xuesong
You are not logged in.
Ask the Community
