• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Factory Design Suite
    Active Contributor
    nstalker
    Connection Orientation Failure
    95 Views, 7 Replies
    11-13-2012 08:08 AM
    I am having problems getting two user assets to connect properly.  It seems like I have tried every possible orientation of  X,Y and Z to no avail.  These are parametric guardrails similar to the guardrail in the system assets.  I tried to even make the connection points in the same orientation as the system asset but it does not work.  The system assets attach to each other fine so I don't know what I'm doing wrong.
    Please use plain text.
    Employee
    Re: Connection Orientation Failure
    11-13-2012 09:46 AM in reply to: nstalker
    nstalker,
    Is this what you're trying to achieve? (See attached.) I was unable to replicate your problem.
    -Ted
    Ted Saufley
    Principal Content Developer
    DLS Manufacturing Engineering
    Active Contributor
    nstalker
    11-13-2012 09:48 AM in reply to: ted.saufley
    Yes but mine will not connect that way. I'm not sure why.
    Employee
    11-13-2012 11:25 AM in reply to: nstalker
    nstalker,
    Please check your Snap settings in the Factory Options dialog box. (See the attached image.)
    -Ted
    Ted Saufley
    Active Contributor
    nstalker
    11-13-2012 11:37 AM in reply to: ted.saufley
    Ted,
    Thank you for your response.  How do I get to the Factory Options dialog box?
    Employee
    11-13-2012 11:44 AM in reply to: nstalker
    If no layout is currently open, click Get Started tab > Factory Launch panel > Factory Options.
    If you do have a layout currently open, then click Factory tab > Options panel > Factory Options.
    Ted Saufley
    Active Contributor
    nstalker
    11-13-2012 11:45 AM in reply to: nstalker
    Thanks Ted!  I adjusted my settings to be like yours and I still have this problem (see attached)
    Employee
    11-13-2012 06:07 PM in reply to: nstalker
    The problem is that the direction of X , Z axis  are not correct when you change the asset variant as 8ft_1_Post. Please make sure the +Z direction is vertical to the landing surface, whilst +X direction is along with the way of chain. Please give a try to the asset I edited as attached.
    -Xuesong
