• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Factory Design Suite
    Valued Mentor
    coreyparks
    Can't publish asset
    216 Views, 7 Replies
    07-10-2012 08:36 AM
    I just fired up 2013 for the first time and went to publish an asset and I get the attached error message.  Any ideas how I need to resolve this?
    Please mark this response "Accept as solution" if it answers your question.
    Corey Parks
    IV2012 Factory Design Suite Ultimate 64bit
    Includes: Inventor Professional, AutoCAD Architecture & Navisworks Manage
    Windows 7 64 bit- Synergis Adept document management software
    16gb RAM --- Nvidia Quadro 4000 2gb
    Please use plain text.
    Employee
    Re: Can't publish asset
    07-10-2012 10:25 AM in reply to: coreyparks
    Hi Corey -
    Are you using an Inventor project that customizes the template location?
    We are trying to use the default DWG template when creating the Dwg during publishing.
      Jeff
    Valued Mentor
    coreyparks
    07-11-2012 07:11 AM in reply to: jeff.pek
    Yes we do have our templates in a central location for all users and in inventor we don't use dwg at all so there is no dwg template in that direcrory.  I copied the Standard.dwg from the Inventor 2013 templates into our standard template location and I still get the same error.  Why would this be different from 2012?  It has always worked fine until 2013.
    Corey Parks
    Valued Mentor
    coreyparks
    07-11-2012 07:24 AM in reply to: jeff.pek
    I am also having another problem that may be tied into this as well.  I can't sync a 3D layout to autocad, it just creates an empty dwg file and then gives me an eror dialog with 4 reasons it may not be working.
    1. the dwg file doesn't even exist yet
    2. what path?
    3. we don't use vault.
    4. Thanks for this one, lol.  Programer must have been in full CYA mode here,
    Corey Parks
    Employee
    07-11-2012 07:51 AM in reply to: coreyparks
    Can you copy both the English and Metric folders into your template location and see if it works?
    Yizhou
    Valued Mentor
    coreyparks
    07-11-2012 08:09 AM in reply to: yizhou.cao
    That appeared to fix both of the problems I was seeing, now I have another.  How do I fix the problem of having a bunch of templates I don't want and don't use that I don't want to upkeep?  Now that I need these templates and they need to be in an area where all users can see them I need to make sure they have all the right iproperties in them so if someone uses them for other things then factory they function properly.  Where are the settings stored for which templates to use?  Why is it different for 2013?  I need to find someway to eliminate these templates as they were never required in the past.  I already had about 30 templates now I have more than twice that!
    Corey Parks
    Employee
    07-11-2012 08:23 AM in reply to: coreyparks
    I am not sure why it's different for 2013. I believe that the only template you need is ANSI (xx).dwg depending on your unit settings. You should be able to delete all the other templates.
    Yizhou
    Active Contributor
    04-09-2013 06:40 AM in reply to: coreyparks
    I had similar problem. Somehow fds is using some generic template that is set by standard and unit and not the one you want. So i solved my problem with migrating all old generic templates i don't use anyway, but are in template folder/subfolder...little bit wierd, imo...
    Factory design suite 2013 premium
    Some old workstation ...
    Fancy HP LCD
    :smileyhappy:
