• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Factory Design Suite
    Dan.M
    Cable and harness between assets
    56 Views, 1 Replies
    12-29-2012 11:12 AM
    Hi
    I get an error when I try to build a wire or cable between two points.
    If i try to pass a segment everything is fine.
    Someone saw this before?
    Dan
    Please use plain text.
    Employee
    Re: Cable and harness between assets
    12-30-2012 07:30 PM in reply to: Dan.M
    Hi Dan,
    I didn't see the error as you. Is it related to the specific data set? If possible, can you share the data with me by Xuesong.bai@autodesk.com.
    -Xuesong
