Factory Design Utilities Forum
Welcome to Autodesk’s Factory Design Utilities Forums. Share your knowledge, ask questions, and explore popular Factory Design Utilities topics.
CONNECTOR PROPERTIES IN FACTORY DESIGN SUITE
6 REPLIES 6
mathavan05
762 Views, 6 Replies
 hai , How to use connenctor properties in factory design suite..?  by using asset variants and fx parameters.?
6 REPLIES 6
jeff.pek
in reply to: mathavan05
Hi -
Thanks for the question.
We have some info regarding connector classes, and connector class properties, in the documentation.
Maybe we can help answer some specific questions you have.
Can you let us know what you're trying to accomplish?
  Jeff
XuesongBai
Hi there,
Attached is the brief workflow document to introduce the connector and connectorclass.
-Xuesong
Please mark as a solution if somehow I got it right.
mathavan05
in reply to: XuesongBai
Thanks a lot, I will try that and inform you.
I have one more doubt in navisworks, how to select the face in navisworks file,
I want to select and apply the material in wall in different colors, if i select that whole wall ll be select.
jeff.pek
Hi -
I'm pretty sure that you don't have face-level selectability in Navisworks itself.
To do this, you'd have to make this change in Inventor, and then the color override should be maintained through the Navisworks import.
Jeff
mathavan05
in reply to: jeff.pek
hai jeff pek,
Thanks again, I need to insert the trees and plants in my model in navisworks, if import from inventor its not showing, but when i generate into video that trees are showing. how i show my trees in navisworks can you explain please. can you tell the best reccommend export video option of material and in autodesk rendering not in presenter.
Mathavan H
mathavan05
Hi. Thanks I tried that file.
Very Sorry I cant understand properly. So Please send any other files or videos links.
Thanks in Advance
