Hai,
I m using factory design suite in that cable harness is not syncronize to autocad, after i used the cable and harness, sync into auto cad, but its not showing in autocad, how to use as a assets, segments only visible in the 2d drawing.
Do you have a picture of this -- in both AutoCAD and Inventor -- or even a sample model that you could share?
Jeff
Thanks for the Reply,
If you are using factory design suite means, just you do some cable harness in factory design suite, after sync it to autocad, it will generate to 2d right, but in this time that harness only not showing in the autocad. that what i m asking how to do that.
