Factory Design Utilities Forum
Welcome to Autodesk’s Factory Design Utilities Forums. Share your knowledge, ask questions, and explore popular Factory Design Utilities topics.
Axles disappeared
5 REPLIES 5
Logos_Atum
467 Views, 5 Replies
Axles disappeared
Hello there,
somehow the axles of the connector points have
disappeared. I tried restarting the program and I
restarted the computer. I can´t remember changing
anything. I tried different quality settings and even
software graphics without any effect. I´ve attached
a screenshot. No XYZ anymore.
Any suggestions?
Kind regards
Daniel
Dogs aren´t flammable.
5 REPLIES 5
XuesongBai
in reply to: Logos_Atum
Hi Daniel,
It seems that the necessary colors  which are used in FDS asset builder, are deleted. So could you please try to copy the folder as below from other machine?
C:\Program Files (x86)\Common Files\Autodesk Shared\Materials\2014\assetlibrary_base.fbm
Or  you need to created an new .ipj file and do it again.
-Xuesong
Please mark as a solution if somehow I got it right.
Logos_Atum
Hello Xuesong,
sadly this did not work at all. I´ve copied the files you
mentioned but no effect was shown so far. I have al-
so tested to do a new ipj but it still is the same. Any
object I do is missing the axles.
I will restart the machine one more time to check if
Inventor needs a clean start in order to acess the
files properly.
Kind regards
Daniel
XuesongBai
Hi Daniel,
Please make sure the Autodesk Appearance library has been added to the project. Generally, Red, Green and Blue will be used for presenting the Axles.
Thanks.
-Xuesong
Logos_Atum
Hello Xuesong,
I will check this! Thanks for your help.
Kind regards
Daniel
Logos_Atum
in reply to: XuesongBai
Hello Xuesong,
thank you - now the axles are back again 😄
Kind regards
Daniel
