Autodesk Factory Design Suite General Discussion
Valued Mentor
Logos_Atum
Message 1 of 7 (249 Views)
Asset problem
249 Views, 6 Replies
11-19-2013 10:03 AM
Hello there,
I did a Factory layout which I would want to publish as an asset.
Can this be done by converting the layout to a ordinary iam?
I can make use of editors, change the data header ect... Is this possible?
It would save a whole lot of time.
Kind regards
Daniel
- 2500K @ 4.2Ghz- 8GB - Radeon7970 -
- Xeon 1230V2 @ stock Ghz- 32GB - W7000-
- 2x Xeon 2670V2 - 64GB - W7000 -
- Factory Design Suite Premium Subscription-
Employee
XuesongBai
Message 2 of 7 (233 Views)
Re: Asset problem
11-20-2013 12:55 AM in reply to: Logos_Atum
 Hi Daniel,
That is interesting requirment. Currently you cannot convert the factory layout assembly to normal assembly.Will the parameter of factory layout as asset be changed?
-Xuesong
Valued Mentor
Logos_Atum
Message 3 of 7 (226 Views)
Re: Asset problem
11-21-2013 02:01 AM in reply to: XuesongBai
Hello Yuesong,
I think it´s no big deal to do an ordinary assembly which I would publish as an asset then.
I just got curious when thinking about the structure of the iam itself.
The parameters would be changed I guess. I should be trying copy and paste from assebly
to *.iam - the associations should not be lost. All I would need to do would be the linking
of the part parameters to the *.iam.
Kiiiiind regards
Daniel
Employee
XuesongBai
Message 4 of 7 (211 Views)
Re: Asset problem
11-24-2013 09:28 PM in reply to: Logos_Atum
Hi Daniel,
As limitation, factory layout assembly cannot be published as asset. Maybe you can "Remove" factory flag by API to convert it as normal assembly, but you can have a try. Good luck.
-Xuesong
Valued Mentor
Logos_Atum
Message 5 of 7 (191 Views)
Re: Asset problem
12-03-2013 04:02 AM in reply to: XuesongBai
Hello Xuesong,
I will try to do so in my spare time- sounds like a fun job.
I wanted to do some customisation work anyway, if you
know some web resource, I´d be grateful and could accept
it as a solution :smileyhappy: Also I would be asking numerous questions
on the issue :smileyvery-happy:
Kind regards
Daniel
Employee
XuesongBai
Message 6 of 7 (184 Views)
Re: Asset problem
12-03-2013 06:18 PM in reply to: Logos_Atum
Hi Daniel,
That is OK. Welcome any question from you.
-Xuesong
Valued Mentor
Logos_Atum
Message 7 of 7 (179 Views)
Re: Asset problem
12-04-2013 01:55 AM in reply to: XuesongBai
Thanks Xuesong - have a most pleasant day
You are not logged in.
Ask the Community
