Show only
Search instead for
It would be nice that and text associated with an item would refill after revdesign. Revdesign is a great tool as long as your drawing is not already annotated, if it is you have to annotate all over again.
Thanks Scott,not a bad work around. I tested it because I am set up to only display text in paperspace viewports. It will work but you have to run the command thru an active viewport. That is the only way it will keep the proper text size that I am looking for. Thanks.
As part of the same issue. Any fill 3D should regenerate any text attached to any item on the designline. I am not sure how that might happen as I think I understand how the text is attached and how the items are managed but it sure would be nice.
