Fabrication CADmep Forum
Welcome to Autodesk’s Fabrication CADmep Forums. Share your knowledge, ask questions, and explore popular Fabrication CADmep topics.
Setting up Mapping
7 REPLIES 7
Message 1 of 8
772 Views, 7 Replies
Setting up Mapping
Very new to this and I have no idea where to start. I am using Revit MEP 2014 and FAB MEP 2014. I am trying to take my HVAC system from Revit to Fab and then create a .maj file. I highlight what I want, select show design line and export using OUT. I open my FabMEP and use processrun to bring in my HVAC system but it does not place it piece by piece if you know what I mean. Its still shows it as one long duct and not seperate pieces to be connected. First, what am I missing? Second, how to fix it? Finally, I know im missing something with mapping but I have no clue what to do. Please, anything helps.
Tags (3)
7 REPLIES 7
Message 2 of 8
davidronson
In Revit there is a Store Designline Elements. Are you using this, or going straight to Out? If you arent, give it a shot and see if your result are different.
______________________________________________
Don't forget to "Accept As Solution" and "Give Kudos" when an acceptable solution has been given.
|| LinkedIn || LinkedIn Fabrication Group ||
Message 3 of 8
in reply to: davidronson
Here is my process:
Highlight everything, filter keeping only mechanical equipment, air exchange and all duct (accessories, fittings and duct).
Store Design Line Element
Filter; keeping Mechanical equipment and air exchange
Store Graphical Elements
Out.
I then go into FabMEP; processrun. A table pops up about mapping but I do not understand it at all (which is where i think i am doing something wrong). I leave everything the way it is and click ok.
Now my air exchange and mechanical equipment come in alone but not solid pieces, just lines. No duct work appears.
May I remind you I have never done this before.
Message 4 of 8
davidronson
When the "table pops up" this is where you align the Revit families with your Services. The program needs to know that for example that the family "Rectangular Duct" is equivilent to your service "Fresh Air Supply."
Also, I have seen many folks very frustrated with the results due to crappy Revit models.
Message 5 of 8
How would I be able to tell if this is a "crappy Revit model" to begin with?
When all the information pops up in my mapping table, all my exhaust for instance will simply just say "Mechanical Exhaust Air 42", each has its own number. Same with Return Air and Supply Air. Is this normal?
Message 6 of 8
davidronson
Yes its normal...kind of. Depending on the quality of company that is putting out the Revit model.
Mechanical Exhaust Air 42 is a Family from Revit, you need to line it up with a Service from CADmep. There is a dropdown next to it where you can assign it to your Exhaust Air service. Once you complete the whole list, you can save the Mappings by clicking at the bottom of the interface.
Message 7 of 8
I believe this model was made in a hurry to complete a contract to match the AutoCAD 2D model.
Is there by chance a way I can create a .map file without importing my model into FabMEP and using the dialog box that pops-up?
Message 8 of 8
davidronson
No this is just the way it works. Each project will have different mappings since they arent always coming from the same source.
