I have found an issue with the straight labels where the print order for the non-standard straight labels are not following the Installed Decoiler Straight Order, but the standard straight labels do follow this priority. Having come across from a much older version of camduct, I am not sure if there are any new settings which are making this happen or whether it is a bug?
The straight order is:
Small Straight Len (separating standard and non-standard lengths into separate reports)
Item Material+Gauge (creating separate lists for each material and gauge in each report)
Item Seam 1 (separates different seams as these are calculated in the report I think)
Item End 2 Size
The order for the non-standard straight labels is seemly quite random, jumping from 1mm to 0.8mm then back to 1mm gauge which I am fairly certain is shouldn't be doing.
Any help here would be greatly appreciated, thanks in advance.
Laurence
