• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk FMDesktop
    Member
    Revit , ADT or both
    116 Views, 8 Replies
    08-03-2006 12:28 PM
    Just a general question. Now that the product is developed in the Autodesk realm... we must expect it to intergrate with revit mostly ? I mean will the best of the features be build around the BIM model or can we expect it to be closely to ADT?
    Surely you can answer me that the product will work with both but since we talk about different technologies, restrictions and limitations will it be closer to Revit or ADT?
    Please use plain text.
    *melanie stone
    Re: Revit , ADT or both
    08-03-2006 12:38 PM in reply to: Katsaras
    how about MAP? :smileywink:
    Seriously though, and I'm just guessing here, but, it's my understand that
    it has been (so far) working with plain autocad objects, so I'd guess plain
    autocad over either of those choices (or ADT over Revit, as adt's dwg files
    can be directly used in acad more than rvt)
    It would be nice to be able to bring in a real, usable model like from
    revit, but, do they see a market for that *yet*? BIM is getting a lot of
    press these days, so I hope so, but, at the same time, if I was a customer
    and not yet using revit, i might resent development dollars being spent on a
    BIM fm application, rather than whatever I am using at that time.
    Melanie Perry
    ***not all who wander are lost***
    http://mistressofthedorkness.blogspot.com/
    wrote in message news:5258381@discussion.autodesk.com...
    closely to ADT?
    Employee
    08-08-2006 08:01 AM in reply to: Katsaras
    All of our current development plans call for FMDesktop to be equally compatible with either Revit or ADT. You are correct to assume that FMDesktop will integrate more information from Revit or ADT than it will from ACAD because there is simply more information available from the vertical applications.
    Mark Evans
    Product Manager, FM Solutions
    Mark Evans
    Senior Product Manager
    AEC Division, Simulation Product Line
    *melanie stone
    08-08-2006 08:32 AM in reply to: Katsaras
    I've got a question for you, Mark.
    So, this will be developed to work with both ADT and Revit content...
    will that all be in one program? or would we, as facility managers have to
    pick one or the other?
    It would be nice for an owner to have the option to accept both file types
    from contractors, but, then you'd be faced with the difficulties of making
    the types work together (say an area is orginally designed with adt then
    renovated with revit or adjacent areas were designed and/or renovated with
    both programs).
    You're just working with file types in their native forms, right? No
    conversion to some other format?
    Melanie Perry
    wrote in message news:5261941@discussion.autodesk.com...
    Mark Evans
    *Revitiscool
    08-08-2006 06:49 PM in reply to: Katsaras
    FmDesktop does not work with Revit yet. It can read native ADT information
    though.
    At my firm we did a lot of research for CAFM solutions and found most
    require you to "polyline" your plans to create rooms and suites. All of them
    work with AutoCAD, most can now recognize and work with ADT space objects.
    None of them work with Revit. This is because until recently Revit did not
    have an API.
    "melanie stone" wrote in message
    news:5262003@discussion.autodesk.com...
    both programs).
    Melanie Perry
    Mark Evans
    Employee
    08-08-2006 07:25 PM in reply to: Katsaras
    In the current version of FMDesktop (6.5), the Facilty Link module is an ACAD plug-in that provides tools for creating space poly-lines, adding or updating the corresponding records in the FMDesktop database, and publishes the floor plan to DWF that is used in the other FMDesktop modules. You can do the same thing using ADT (not taking advantage of ADT space objects).
    FMDesktop uses DWF because it is lightweight, can carry non-graphic data, and is Autodesk's stated direction for applications that are "downstream" consumers of data from design applications. ADT, ABS, and the Revit series of applications all produce DWF files that contain some degree of object intelligence within them.
    Mark Evans
    Mark Evans
    *melanie stone
    08-09-2006 05:24 AM in reply to: Katsaras
    I realize that, is why I said "So, this will be developed"
    So, it sees the AEC objects from ADT already with no problems?
    Well, yes, I know of no cafm program that even mentions revit, but,
    they, I'm sure are waiting for the market to start taking over before
    they spend development dollars to support a program that a minority
    are using.
    I'm just happy to hear that the option will be provided in some form...
    at some point in time.
    thanks. :smileyhappy:
    Melanie Perry
    "Revitiscool" <0> wrote in message news:5262795@discussion.autodesk.com...
    though.
    have an API.
    both programs).
    Melanie Perry
    Mark Evans
    *melanie stone
    08-09-2006 05:29 AM in reply to: Katsaras
    :smileywink: Thanks Mark. I realize that I can't expect to hear too much about the
    future plans for the program, as they are still under development and you
    don't want to make any promises.
    Alright, I understand the use of DWF. But, one thing I am curious about, is
    there some sort of automation in the creation of the DWF? Like, after I've
    modified a drawing or a set of drawings, is it automatically republished? or
    is there a one-button publish? or would I have to do some sort of plotting
    setup each time. (I'm sure these are rather elementary questions, but,
    please, humour me, as always)
    Thanks again for taking the time out to answer questions, Mark. It's always
    appreciated.
    Melanie Perry
    wrote in message news:5262799@discussion.autodesk.com...
    Mark Evans
    *melanie stone
    08-09-2006 09:05 AM in reply to: Katsaras
    ooh, check me out... I'm *so* in this class... I should hold all of my silly
    questions until after I've gotten my training this year. :smileywink:
    When Revit® Meets Autodesk® FMDesktop:
    Description:This session will introduce management professionals,
    architects, and space planners to the powerful relationship that develops
    when parametric software meets facilities management software. You'll see
    how to integrate your BIM model and facilities data into a super-charged
    facilities management tool. Learn how to create up-to-date space, asset,
    occupancy, and move management information for your facility or campus.
    Key Topics:
    - Creating the BIM model
    - Creating facilities management information within the BIM model
    - Exporting facilities management information to DWF files
    - Importing facilities information into FM Desktop
    - Creating up-to-date space, asset, occupancy, and move management
    information using FM Desktop
    Who Should Attend:Facility managers, architects, space planners
    Speaker(s):Clyne Curtis
    Melanie Perry
    news:5263047@discussion.autodesk.com...
    appreciated.
    Melanie Perry
    Mark Evans
