• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk FMDesktop
    *Wanderer
    Mass changes of Property Sets info fields?
    1473 Views, 5 Replies
    09-03-2008 07:52 AM
    I'm using ACA 2008 with FMD 7.1
    I created all of my spaces (all in one go, so they shouldn't have
    duplicate 'number's, as I've experienced in the past and I know will
    cause problems). Then, I made sure all of the space 'Name's were unique
    (using our standard space tag of CC-##-###).
    Now I'm ready to use this existing space plan with FMD. I log the
    drawing, apply FMSpaces Property Set Definition (PSD) and sundry.
    Now, my problem comes with the Extended Data Tab in ACA.
    There are two fields, 'Name' and 'Number' that I'm concerned with. I'd
    like to copy the field 'name' into the field 'number' so that it's
    unique, and I can more easily identify the space once it's imported into
    FMD, without the meaningless 'number' field to throw me off and take up
    space.
    I'd like to know how to batch change that, if it's possible?
    I could go into FMD and copy over the column from the backend, but,
    while that seems to work for my database, it's going to break my
    connection with the original drawing, making future updates a nightmare
    and require a huge amount of rework.
    I'd love some advice/insight on how I should be going about this.
    Thanks for your time,
    Melanie Perry
    ***not all who wander are lost***
    http://Tech-Tea.com
    http://AUGI.com/AutoCAD
    http://mistressofthedorkness.blogspot.com
    Please use plain text.
    *Wanderer
    Re: Mass changes of Property Sets info fields?
    09-05-2008 05:40 AM in reply to: *Wanderer
    Okay, I know this technically won't work in ACA, since the 'number'
    field in ACA will not accept letter characters.
    Dagnabbit. ~grumble~
    > There are
    > space.
    > conne
    > Melanie Perry
    > http://Tech-Tea.com
    Employee
    09-06-2008 01:01 PM in reply to: *Wanderer
    I'm not sure I am following you completely since I am sleep deprived and not an ACAD (any flavor) expert. But I might trigger a different way of thinking about it.
    Do you really need to move this field in ACA? What if you included that field in the DWF that you export and then apply that field mapping when you import the DWF in Facility Manager? Would that give you the result you seek?
    Mark Evans
    Mark Evans
    Senior Product Manager
    AEC Division, Simulation Product Line
    *Wanderer
    09-08-2008 06:19 AM in reply to: *Wanderer
    Well, I can't really move the field in ACA since it has non-numeric
    characters, but, since I have unique space designations, I'm being
    irritated by these random numbers, I'd rather not see them (and have
    them confuse the end users).
    I'm not sure what you're getting at with Field Mapping? Are you talking
    about the actual 'field' feature within AutoCAD, or are you referring to
    the fields in the space properties?
    Thanks!
    Melanie Perry
    http://Tech-Tea.com
    > Mark Evans
    Employee
    09-08-2008 06:27 AM in reply to: *Wanderer
    I mean, when you use the DWF Import command in Facility Manager, on the dialog that comes up after you select the DWF file, you can hit the "Map Properties" button. That will open a dialog that lets you map any properties attached to the spaces in the DWF to space attributes in the FMDesktop database. That would allow you to move your "unique space designations" into the "Common Name" field in FMDesktop, for example.
    Of course, I am assuming you are worried about confusing users of FMDesktop reports. If you mean confusing users of ACA drawings, then I've missed the point entirely.
    Mark Evans
    Mark Evans
    *Wanderer
    09-08-2008 07:13 AM in reply to: *Wanderer
    Hmm, okay, I think I've got it now! I'll have to give that a try.
    Yes, you've read my point correctly. I don't want to confuse my end
    users (I'm the only ACA user, I just assumed I'd have to make any
    changes within ACA so that the next time I exported/imported my
    documents, that they wouldn't have a disconnect with my FMD database).
    Thanks!
    Melanie Perry
    http://Tech-Tea.com
    > Mark Evans
