• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk FMDesktop
    Active Member
    Label Styles
    78 Views, 1 Replies
    04-24-2007 03:19 PM
    Does anyone know how to get the Equipment Label to work? For instance where does the label pull the equipmnent information from?
    Thanks in Advance
    Please use plain text.
    Employee
    Re: Label Styles
    04-27-2007 03:02 PM in reply to: jar92380
    Assuming you are in Facility Manager 7... The equipment label displays the current value for each equipment field that you request in the label setup. For example, if you select "Description", the current value stored in the Description field for each piece of equipment will be displayed over the equipment. You can edit these values either by selecting equipment graphically, or by scrolling through them with the equipment forms.
    Or, your question may be how to get equipment in. Today, you can only create equipment in the drawing by using Facility Link.
    Mark Evans
    Senior Product Manager
    AEC Division, Simulation Product Line
    Autodesk, Inc.
