• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk FMDesktop
    Active Member
    Finish (or Equipment) Replacement Reports
    1315 Views, 1 Replies
    08-25-2008 10:37 AM
    Does anyone else use the finish or equipment replacement reports? We have started using them and have found a couple of issues. If you have a finish or piece of equipment with a lifecycle of 5 years and due to be replaced in 2009 and you run a replacement report for the next 10 years, the numbers for 2014 are going to be inaccurate because the finish is going to be reported on only once even though the finish that will replace it will need to be replaced in 2014.
    It seems that the replacement reports are only going to be accurate as far out as your shortest lifecycle (in our case, 5 years).
    Can anyone think of a way to work around this at least temporarily?
    Please use plain text.
    New Member
    Re: Finish (or Equipment) Replacement Reports
    09-08-2008 08:29 AM in reply to: jwulf
    My guess is Josh that its probably just something that needs to be modified in the query for those reports. Which one of the replacement reports are you using? I'll take a look at the query and see if I can find something that is being omitted.
    Jon Luby
