• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk FMDesktop
    Distinguished Contributor
    FM Desktop
    120 Views, 13 Replies
    06-30-2006 04:14 AM
    I'm curious, does FM Desktop have the ability to read IFC and RVT models?
    Scott Robbins
    TRO/The Ritchie Organization
    Please use plain text.
    Employee
    Re: FM Desktop
    07-05-2006 08:52 AM in reply to: SRobbins
    Scott,
    Not today, but... As FMDesktop is further developed in the Autodesk family, you can expect to see much tighter integration with Revit.
    The IFC option is an interesting idea that merits more investigation. Perhaps you can share some scenarios where an IFC import would be important to you?
    Mark Evans
    Product Manager, FM Solutions
    Mark Evans
    Senior Product Manager
    AEC Division, Simulation Product Line
    Autodesk, Inc.
    Re: FM Desktop
    07-06-2006 05:01 AM in reply to: SRobbins
    Hey Mark,
    I'm speaking from an Architects view point that works close with developers
    that rent out alot of retail space. I would never want to give up our Revit
    model. The custom families were built to an extent that they are treated as
    intellectual property. These parameters and methods, give us a genuine
    advantage over the competition and our families do alot more for us then
    most families found out there. With that view point in mind we would hate to
    send a Revit BIM out to a client for FM only to have the client send it out
    to the next guy who would get more then just or work on the building. They
    would get our intelligent objects.
    I do however for see more of my clients asking for the model for us in tools
    like FM Desktop. I would like to give them something generic. An IFC seems
    to be the perfect case to carry this information in for their use and mine.
    I can give them an IFC for use. Seeing as IFC is the current solution for
    BIM formats, I can feel comfortable offering the IFC from Revit and not
    worrying about the client demanding more. If the client asks what programs
    can I use to read this? I can respond Autodesk FM Desktop reads IFC.
    With IFC in FMDesktop you have provided me with another option to come to
    common grounds with the client. I don't risk giving up the advantage of our
    custom families and the client still gets a BIM for use in his FM Desktop.
    He can still use the BIM for use by his in house architect for layout/tenant
    changes.
    Scott
    wrote in message news:5227304@discussion.autodesk.com...
    Scott,
    to you?
    Mark Evans
    Employee
    Re: FM Desktop
    07-06-2006 05:52 AM in reply to: SRobbins
    That's great input, Scott. Thank you for taking the time to crank it out for us.
    Mark Evans
    Mark Evans
    Autodesk, Inc.
    *David Haynes - Ideate
    Re: FM Desktop
    07-06-2006 10:24 PM in reply to: SRobbins
    Just food for thought....
    If you replace "AutoCAD block" for every time it says "families" (below) you
    will have stated what architects and engineers loudly said in 1988-1992.
    What changed in that time period? Clients demanded that the design industry
    provide .dwg files - we in the design industry balked, but provided the
    information. In the foreseeable future, I believe clients will demand Revit
    files, including the families.
    I believe your differentiator will not be those families created, but the
    ability to design and document your design in a coordinated and thoughtful
    manner.
    I am not in disagreement about IFC, but IFC is very limited in the
    information it provides. IFC gives information in the lowest common basis,
    in this way it keeps the equality of the information. IFC would need to
    greatly improve itself to be a true translator for BIM information. Maybe
    XML (aecXML) will be a better format? Note that the IAI is looking into
    aecXML.
    Regarding FM:
    I think it is very necessary that FM be able to carry the BIM information
    forward to the Owner (that is really the bottom line).
    David Haynes, AIA
    Ideate, Inc.
    www.ideateinc.com
    ___________________________________________________________________________________
    wrote in message news:5228414@discussion.autodesk.com...
    Hey Mark,
    changes.
    Scott
    Scott,
    to you?
    Mark Evans
    Re: FM Desktop
    07-07-2006 04:59 AM in reply to: SRobbins
    The client will defiantly want that BIM and will defiantly want to use their
    BIM in FMDesktop. I think programs like revit redefine digital information.
    ACAD files were just line work. Revit files can contain and reveal more
    then just the BIM. They can reveal a work flow, a system and a way of
    working. Alot more work is in a family file then in a block. I think while
    clients might demand the actual rvt file, Architects will be more guarded
    then with DWG. DWG you just lose the secrets of your layer standards(unless
    you do a layer translater). With Revit the parameters and assembly of family
    types can reveal how your work. I will not give up the raw rvt file, and I
    am very avid with my full time company that they do not give it up.
    But your right, what firms crumble to demands and what firms find ways to
    work around will define what is given up.
    "David Haynes - Ideate" wrote in message
    news:5229685@discussion.autodesk.com...
    manner.
    aecXML.
    Regarding FM:
    David Haynes, AIA
    Ideate, Inc.
    www.ideateinc.com
    Hey Mark,
    changes.
    Scott
    Scott,
    to you?
    Mark Evans
    *melanie stone
    Re: FM Desktop
    07-07-2006 05:40 AM in reply to: SRobbins
    As someone who is not a designer, I try to have sympathy for your position
    and not wanting someone else to have access to all of your hard work (and
    the
    obvious leg up you have now that you've created the families that facilitate
    your work), but, from my facilities perspective, the most motivating thing
    should be the **client contract**.
    We have firms who hassle with us about getting CAD documentation period...
    and we're not happy with those firms. Then we have firms who understand and
    happily accept our contract and give us what we need to maintain our
    systems.
    Right now of course we're using strictly 2d dwg files, but, I've been
    watching Revit Systems (and abs) eagerly thinking about all of the ways such
    design
    documentation could help us maintain our facility. If we end up hiring a
    company
    to design for us with such a tool, then part of our contract will be that we
    end
    up with an entirely usable model.
    Not every facility has someone on staff who will demand such things. So, the
    companies who are *not* willing to provide them will still be able to find
    plenty of work... but, not from me.
    wrote in message news:5229851@discussion.autodesk.com...
    manner.
    aecXML.
    Regarding FM:
    David Haynes, AIA
    Ideate, Inc.
    www.ideateinc.com
    Hey Mark,
    changes.
    Scott
    Scott,
    to you?
    Mark Evans
    Employee
    Re: FM Desktop
    07-07-2006 06:44 AM in reply to: SRobbins
    It's nice to hear from someone on the "owner's" side of the equation. Thank you, Melanie.
    Maybe IFC is not the right answer, but it seems like we should be able to use a file format that gives the owner/client the 2D and 3D graphical representation they desire and carries the attribution (sizes, capacities, upstream/downstream relationships) of all the equipment and components. That could give the client the information they need for operations and maintenance without giving up the Revit families or other intellectual property that the AE wants to keep. Is this thinking on the right path?
    Mark Evans
    Autodesk, Inc.
    *melanie stone
    Re: FM Desktop
    07-07-2006 06:51 AM in reply to: SRobbins
    Thank you, Mark... I can't expect anyone to give me what I want if I don't
    voice my needs. :smileywink: I do think it is important too for both contractor and
    owner to empathize and realize the different ways that we both use our data.
    It's hard to say *exactly* what we'll need... not only do we have
    maint/upkeep/future planning to keep in mind for ourselves... but, it's also
    a case of being able to easily share bits and pieces of the information with
    contractors who will renovate those spaces for us in the future.
    Not being fully familiar with Revit Systems and the type of data it could
    potentially carry... nor FMsystems and it's data... ~shifty eyes~ nor our
    BAS or MP2 systems, with which I'd like to be able to exhance data with...
    so I'm not sure what all a contractor would need from us in the future (not
    something I could really ask right now, as only one of our contractors has
    even started implementing Revit, and not on any of our jobs, our mep guys
    are the furthest back as to releases/software packages - still using acad).
    wrote in message news:5230003@discussion.autodesk.com...
    you, Melanie.
    Re: FM Desktop
    07-07-2006 07:17 AM in reply to: SRobbins
    That is the right thinking path. Maybe it isnt up to the point that FMs
    like Melanie needs which might not make it the right answer for FM Desktop
    at the moment. Possibly 3D DWF is the solution(not sure if FMDesktop can
    import that).
    I have been playing with IFC and it seems like the most viable option from
    the end of the designer. Maybe in the future it will be better for FM
    Desktop. It can be imported into Revit and BIM programs and be used the
    same as a RVT file would be. Meaning that walls maintain their basic
    functionality(height, length, width) and doors, windows, ect. are still
    schedulable.
    What it boils down to on my end(which is probably not your concern
    considering I'm not the one you are marketing to) is the more options you
    give FM Desktop to import various forms of BIM the more I can say, FM
    Desktop will import this file format that I am giving you.
    you, Melanie.
