Autodesk FM
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
*melanie stone
info to put in cafm system?
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
168 Views, 6 Replies
12-24-2004 06:12 AM
I put together a list for my boss trying to pin
down exactly what information we might want
to record in a CAFM program...
(please chime in with the info you record, and
how useful it is...)
Potential Information to be Gathered for Facilities Management Asset Survey
Door Number
Room Title
Room Usage
Dept Ownership
Square Footage
Ceiling Height
Finishes
Wall Type
Finish Type/Color
Base Type
Flooring
Ceiling Type
Casework
Countertop Materials
Door(s)
Door Material
Door Size
Door Special Function
Windows?
Lighting
Electrical (# of to be incl?)
Communications
Equipment
Misc Equipment
Plumbing Equipment
Med Gasses/Services
Special HVAC
details and examples of categories
Door Number
CC-Ll-001
CM-01-001
Room Title
Conference Room 'A'
IDF 'QT 1'
Plans Room
Room Usage
Conference
Exam
Reception
Storage
Support
Treatment
Utility
Waiting
Dept Ownership
Square Footage
Ceiling Height
Finishes
Wall Type
Drywall
Brick
CMU
Partition
Folding Partition
Plaster Cement
Plaster Gypsum
Finish Type/Color
Fabric
Vinyl
Glazed (tile)
Paint color/type
Tan/Green/White/etc.
Flat, semi-gloss, glossy
Unfinished
Base Type
Ceramic Tile
Rubber
Tile
Terrazzo
Vinyl
Flooring
Carpet
Tile
Conductive
Rubber Sheet
Terrazzo
Vinyl Sheet
Vinyl Tiles
Unfinished
Ceiling Type
Acoustical Adhesive
Acoustical Conceal
Acoustical Fire-Rated
Acoustical Lay-in
Drywall
Cement Plaster
Gypsum Plaster
Unfinished
Casework
Custom P. Lam.
Custom Steel
Custom Wood
Modular P. Lam.
Modular Steel
Modular Wood
Acid Resistant
Corrosion Resistant
Epoxy Resin
Plastic Laminate
Solid Surface
Stainless Steel
Door(s)
Door Material
Glass
Hollow Metal
P. Lam.
Wood
Door Size
Closer
Power Assist
Hold Open
Vision Panel
Lock
Key Code/deadbolt/pusbutton/multiple
Windows?
Lighting
Fluorescent
Incandescent
Double-Switched
Dimmable Incandescent
High Intensity Discharge
Under-Cabinet Task Light
Indirect
Special Illumination Level
Other
110v outlet
220v outlet
Wiremold
Emergency 110
Emergency 220
X-Ray - Portable
Communications
Telephone
Computer Outlet
Intercom
Nurse Call
Paging
Phisiological Monitoring
TV
CCTV
other
Equipment
Misc Equipment
Chalk Board
Coat Hooks
Computer
Copier Countertop
Copier Floor
Fax Machine
Hood types
Aux, recirc, ext vent, etc
Printer
Steam Bath
Tack Board
Dry-Erase Board
Plumbing Equipment
Flushing Rim Sink
Counter Sink
Cup Sink
Electric Water Cooler
Emergency Eyewash
Emergency Shower
Floor Drain
Lavatory
Mop Receptor
Scrub Sink
Shower
Tub
Urinal
Water Closet
Plumbing Controls
Aerator Valve
Conventional
Diverter Valve
Electric Eye
Foot
Gooseneck
Hose Spray
Knee
Plaster
Wristblades
Plumbing Specialties
Acid
Handicapped
Radioactive
Vacuum Breaker
Med Gasses/Services
Oxygen
Medical Suction
Anesthesia Evac.
Compressed Air
Nitrogen
Nitrous Oxide
Natural Gas
Deionized Water
Chilled Water
Hot Water
Steam
Special HVAC
Positive Filtered
Negative Isolation
Special Environment
Temperature
Variance
Humidity
Re: info to put in cafm system?
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
02-04-2005 06:15 AM in reply to:
*melanie stone
Melanie,
Your listing a lot of potentially useful information, but... when an organization is deciding what information to capture in a survey like this, they need to keep in mind a few things:
1. short term benefit of the results (what, we are being audited?)
2. long term benefit of the results - either you want to archive the results or that part of the facility has little change or you have valuable assets to manage
3. on-going maintenance of the data - this is usually the kicker... managers think they really want the data but don't budget for the administrative cost of keeping the data relatively current. Once the data is out of date it is useless.
4. If the audit includes equipment or space that could benefit from a real preventative maintenance program, make certain that appropriate data is captured that would facilitate the PM setup
Bottom line is... don't bother capturing data that has little or no use to your bottom line.
*melanie stone
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
02-04-2005 06:41 AM in reply to:
*melanie stone
CAFMboss, thanks for the input.
You bring up very valid points. I just shared the list because... well it
was just gathering dust. I was asked to put together an exhaustive list of
anything that we MIGHT want to track in a CAFM program, of course, noone
from my company has even bothered looking at it.
Anyway, the information gathered, of course, would be open to debate by all
departments accesssing that data and assessing what they already track, who
would actually be willing to pay for the the upkeep, etc. But, of course, we
haven't made any further progress on hiring staff or utilitizing software...
I'm sure the main things we'd benefit from with a program here would be
ownership, room use/type, major equipment (now, would this include
mechanical, clinical, electrical??? that's very open to debate), and most
likely finishes.
thanks for the feedback! much appreciated!!!
"cafmboss" wrote in message
news:2373814.1107526584582.JavaMail.jive@jiveforum 1.autodesk.com...
> Melanie,
> You're listing a lot of potentially useful information, but... when an
> your bottom line.
*Wanderer
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
05-09-2007 07:12 AM in reply to:
*melanie stone
HA!
I *knew* posting this list would come in handy!!!
I've had about 3 computers since this time and long ago lost this little
summary here, but, recalled posting it. woohoo!
Anyway, *FINALLY* approved for a pilot here, and reporting on what I'm
about to do a survey on.
So, here's my modified list of what I plan on surveying in my pilot
(still awaiting my boss's feedback, it might change, it might not):
Data collected will be the following:
[items in brackets are from existing plans]
Department Ownership [ddd]
Room Usage
Public Room Numbers
Visible Static Equipment (location of FCU's, etc)
AHU that serves area [aaa]
Asbestos status [bbb]
Sprinkler Head Types [bbb]
Fire Alarm Pull Stations [ddd]
?Plumbing Stack locations? [aaa] (we have a survey of this from a couple
years back, would it be useful, you think?)
Will be brought over from plans:
Square footage
Plumbing fixtures
Elevators/Stairs/Columns
Door numbers
There will also be the ability to include the MEPFP CAD files in plan
view, just to demonstrate the ease of navigation.
Oh, and whether or not it matters, we will be doing our pilot with
FMDesktop (our company had purchased Archibus before my time, but, never
really did anything with it, and back in 2004, that was the program I
was evaluating for our project, but, never got the budgeting for. ~shrug~).
Cheers!
Melanie Perry
***not all who wander are lost***
http://mistressofthedorkness.blogspot.com
melanie stone wrote:
> I put together a list for my boss trying to pin down exactly what information we might want to record in a CAFM program...
> (please chime in with the info you record, and how useful it is...)
> Door Number
> Room Title
> Room Usage
> Dept Ownership
> Square Footage
> Ceiling Height
> Finishes
> Wall Type
> Finish Type/Color
> Base Type
> Flooring
> Ceiling Type
> Casework
> Door(s)
> Door Material
> Door Size
> Windows?
> Lighting
> Communications
> Equipment
> Misc Equipment
> Plumbing Equipment
> Med Gasses/Services
> Special HVAC
> Door Number
> CC-Ll-001
> CM-01-001
> Room Title
> Conference Room 'A'
> IDF 'QT 1'
> Plans Room
> Room Usage
> Conference
> Exam
> Reception
> Storage
> Support
> Treatment
> Utility
> Waiting
> Dept Ownership
> Square Footage
> Ceiling Height
> Finishes
> Wall Type
> Drywall
> Brick
> CMU
> Partition
> Folding Partition
> Plaster Cement
> Plaster Gypsum
> Finish Type/Color
> Fabric
> Vinyl
> Glazed (tile)
> Paint color/type
> Unfinished
> Base Type
> Ceramic Tile
> Rubber
> Tile
> Terrazzo
> Vinyl
> Flooring
> Carpet
> Tile
> Conductive
> Rubber Sheet
> Terrazzo
> Vinyl Sheet
> Vinyl Tiles
> Unfinished
> Ceiling Type
> Acoustical Adhesive
> Acoustical Conceal
> Acoustical Lay-in
> Drywall
> Cement Plaster
> Gypsum Plaster
> Unfinished
> Casework
> Custom P. Lam.
> Custom Steel
> Custom Wood
> Modular P. Lam.
> Modular Steel
> Modular Wood
> Acid Resistant
> Corrosion Resistant
> Epoxy Resin
> Plastic Laminate
> Solid Surface
> Stainless Steel
> Door(s)
> Door Material
> Glass
> Hollow Metal
> P. Lam.
> Wood
> Door Size
> Closer
> Power Assist
> Hold Open
> Vision Panel
> Lock
> Windows?
> Lighting
> Fluorescent
> Incandescent
> Double-Switched
> Indirect
> Other
> 110v outlet
> 220v outlet
> Wiremold
> Emergency 110
> Emergency 220
> X-Ray - Portable
> Communications
> Telephone
> Computer Outlet
> Intercom
> Nurse Call
> Paging
> TV
> CCTV
> other
> Equipment
> Misc Equipment
> Chalk Board
> Coat Hooks
> Computer
> Copier Countertop
> Copier Floor
> Fax Machine
> Hood types
> Printer
> Steam Bath
> Tack Board
> Dry-Erase Board
> Plumbing Equipment
> Flushing Rim Sink
> Counter Sink
> Cup Sink
> Emergency Eyewash
> Emergency Shower
> Floor Drain
> Lavatory
> Mop Receptor
> Scrub Sink
> Shower
> Tub
> Urinal
> Water Closet
> Plumbing Controls
> Aerator Valve
> Conventional
> Diverter Valve
> Electric Eye
> Foot
> Gooseneck
> Hose Spray
> Knee
> Plaster
> Wristblades
> Acid
> Handicapped
> Radioactive
> Vacuum Breaker
> Med Gasses/Services
> Oxygen
> Medical Suction
> Anesthesia Evac.
> Compressed Air
> Nitrogen
> Nitrous Oxide
> Natural Gas
> Deionized Water
> Chilled Water
> Hot Water
> Steam
> Special HVAC
> Positive Filtered
> Negative Isolation
> Special Environment
> Temperature
> Variance
> Humidity
Room Usage
Public Room Numbers
Square footage
Plumbing fixtures
Door numbers
Cheers!
Melanie Perry
> Door Number
> Room Title
> Room Usage
> Dept Ownership
> Square Footage
> Ceiling Height
> Finishes
> Wall Type
> Finish Type/Color
> Base Type
> Flooring
> Ceiling Type
> Casework
> Door(s)
> Door Material
> Door Size
> Windows?
> Lighting
> Communications
> Equipment
> Misc Equipment
> Plumbing Equipment
> Med Gasses/Services
> Special HVAC
> Door Number
> CC-Ll-001
> CM-01-001
> Room Title
> Conference Room 'A'
> IDF 'QT 1'
> Plans Room
> Room Usage
> Conference
> Exam
> Reception
> Storage
> Support
> Treatment
> Utility
> Waiting
> Dept Ownership
> Square Footage
> Ceiling Height
> Finishes
> Wall Type
> Drywall
> Brick
> CMU
> Partition
> Folding Partition
> Plaster Cement
> Plaster Gypsum
> Finish Type/Color
> Fabric
> Vinyl
> Glazed (tile)
> Paint color/type
> Unfinished
> Base Type
> Ceramic Tile
> Rubber
> Tile
> Terrazzo
> Vinyl
> Flooring
> Carpet
> Tile
> Conductive
> Rubber Sheet
> Terrazzo
> Vinyl Sheet
> Vinyl Tiles
> Unfinished
> Ceiling Type
> Acoustical Adhesive
> Acoustical Conceal
> Acoustical Lay-in
> Drywall
> Cement Plaster
> Gypsum Plaster
> Unfinished
> Casework
> Custom P. Lam.
> Custom Steel
> Custom Wood
> Modular P. Lam.
> Modular Steel
> Modular Wood
> Acid Resistant
> Corrosion Resistant
> Epoxy Resin
> Plastic Laminate
> Solid Surface
> Stainless Steel
> Door(s)
> Door Material
> Glass
> Hollow Metal
> P. Lam.
> Wood
> Door Size
> Closer
> Power Assist
> Hold Open
> Vision Panel
> Lock
> Windows?
> Lighting
> Fluorescent
> Incandescent
> Double-Switched
> Indirect
> Other
> 110v outlet
> 220v outlet
> Wiremold
> Emergency 110
> Emergency 220
> X-Ray - Portable
> Communications
> Telephone
> Computer Outlet
> Intercom
> Nurse Call
> Paging
> TV
> CCTV
> other
> Equipment
> Misc Equipment
> Chalk Board
> Coat Hooks
> Computer
> Copier Countertop
> Copier Floor
> Fax Machine
> Hood types
> Printer
> Steam Bath
> Tack Board
> Dry-Erase Board
> Plumbing Equipment
> Flushing Rim Sink
> Counter Sink
> Cup Sink
> Emergency Eyewash
> Emergency Shower
> Floor Drain
> Lavatory
> Mop Receptor
> Scrub Sink
> Shower
> Tub
> Urinal
> Water Closet
> Plumbing Controls
> Aerator Valve
> Conventional
> Diverter Valve
> Electric Eye
> Foot
> Gooseneck
> Hose Spray
> Knee
> Plaster
> Wristblades
> Acid
> Handicapped
> Radioactive
> Vacuum Breaker
> Med Gasses/Services
> Oxygen
> Medical Suction
> Anesthesia Evac.
> Compressed Air
> Nitrogen
> Nitrous Oxide
> Natural Gas
> Deionized Water
> Chilled Water
> Hot Water
> Steam
> Special HVAC
> Positive Filtered
> Negative Isolation
> Special Environment
> Temperature
> Variance
> Humidity
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
08-10-2007 08:53 AM in reply to:
*melanie stone
What about technology equipment (desktop/laptop/server)? Do you record this information also?
*Wanderer
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
08-10-2007 09:09 AM in reply to:
*melanie stone
Not at all. 75% of the information I mentioned is actually recorded by
others. But, the others are shops within my departmental group.
We won't be recording things at all that belong to IT or
Telecommunications, Clinical Engineering, Patient Transport, Key Control
or others outside of the Facilities and Engineering group.
Keeping in mind this is only a Pilot first to solidify the uses and to
gain support from within my own group. Then, as time and staff are
allocated, we can look at bringing in the other groups.
The term 'information kingdoms' is brought up quite a bit in our field
for good reason.
Melanie Perry
for good reason.
Melanie Perry
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
09-15-2007 07:31 AM in reply to:
*melanie stone
Hi Mel, I'd take the other approach and take the global view scoping it to show how it can manage/impact all those other services. That way you can show the business benefit as a whole and even have a rational to challenge the silo mentality.
Then take that global view and only expose progressive implementation and what's applicable to the bus. unit you are dealing with and who's funding that part of the change.
Doing something like that, but not FM based, right now.
