• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk FM
    *Paddleford, Jace
    facility management / autocad help. ASAP
    176 Views, 15 Replies
    01-16-2003 11:37 PM
    the firm i work for has been asked to do some facility management. what the
    client is wanting (they have autocad) is to be able to click on a
    workstation on the floor plan and it give them the information of that
    employee. i have no earthly idea how that is going to work. is there some
    autodesk software that is designed for this type of work? any help????
    Please use plain text.
    *Brown, Anne
    Re: facility management / autocad help. ASAP
    01-16-2003 11:45 PM in reply to: *Paddleford, Jace
    Jace -
    Take a look at the discussion group for Facilities Management and
    ask for help there.
    FACILITIES MANAGEMENT
    http://discussion.autodesk.com/WebX?14@@.f12d9f4 or
    news://discussion.autodesk.com/autodesk.fm
    Anne Brown
    Manager, Moderator
    Autodesk Product Support Discussion Groups
    Discussion Q&A: http://www.autodesk.com/discussion
    Jace Paddleford wrote:
    > the firm i work for has been asked to do some facility management. (snip)
    *Brower, Dann
    01-16-2003 11:46 PM in reply to: *Paddleford, Jace
    You could make each workstation a block with preset and hidden atributes.
    Then when you type attedit it brings up all the info you gave it.
    Then if someone moves or quits you can change the info easily.
    "Jace Paddleford" wrote in message
    news:71AE9F63108EBA740959014D968F733E@in.WebX.maYIadrTaRb...
    the
    *Paddleford, Jace
    Re:
    01-16-2003 11:51 PM in reply to: *Paddleford, Jace
    thanks Anne, i hadnt noticed that group.
    Dann - ive thought of that, but we are talking around 600 employees at this
    location, and i have a sneaking suspicion that this will grow to the entire
    company 2000+ employees. it could / would work, but was wondering what
    options there are out there.
    thanks for the suggestion
    "Dann Brower" wrote in message
    news:092EE95362C54BE7C7299B68DFF4E67D@in.WebX.maYIadrTaRb...
    > the
    some
    Valued Contributor
    01-17-2003 12:13 AM in reply to: *Paddleford, Jace
    This probably won't help you, but with ADT you can do exactly what you what you want.
    *johnson, dc
    Re:
    01-17-2003 12:21 AM in reply to: *Paddleford, Jace
    you could look into arcview as well
    Dave C. Johnson
    WWC Engineering
    Sheridan WY.
    Windows 2k2
    Acad Map 5
    Survcadd XML
    remove OUT to reply
    Distinguished Contributor
    Re:
    01-17-2003 12:40 AM in reply to: *Paddleford, Jace
    If you don't have ADT and you don't have Arcview and you are limited to what you have, is this not, then, an appropriate place to use AutoCAD's database connectivity?.
    Beyond that I would be over my head as to the specific how-tos. A2K shipped with db_sample.dwg and db_sample.mdb (Microsoft Access database) that did/does do this sort of application. A starting point at any rate
    JimL
    *Paddleford, Jace
    01-17-2003 01:09 AM in reply to: *Paddleford, Jace
    an update - just meet w/ the client. they are wanting to somehow link a
    drawing to their sql database. this way they can locate employees by floor
    / department, either by the database or floor plan. i think the floor plan
    would be a dwf format rather than a dwg.
    im not sure what im getting myself into.................
    the
    01-17-2003 05:57 AM in reply to: *Paddleford, Jace
    If they have AutoCAD, you may not need much else. You could create a block of the workstation and assign attributes (text information) to each with whatever information (fields) you want to be displayed. AutoCAD 2002 also allows an easy way of extracting the information to a spreadsheet. Very simple and straight-forward. Hope this helps.
    Dave LaComb, AIA
    *Gazit, Arad
    Re:
    01-18-2003 01:01 AM in reply to: *Paddleford, Jace
    Jace hi,
    The program that should be able to do what you need is Autodesk Map.
    Map can help you connect different AutoCAD objects to more Data (In or out
    of the file).
    It can also help query data based on different criteria: Names, Location and
    much more.
    Map 5 or 6 can enable you to migrate all your drawing data (When too large)
    to Oracle Spatial Database.
    You should look into it.
    Arad
    news:B95917FCD323F06B06CCC3AB75ED0EA0@in.WebX.maYIadrTaRb...
    floor
    plan
    > the
    some
