Autodesk FM
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Informatio n on new Autodesk login system
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
758 Views, 5 Replies
08-26-2008 12:30 PM
Information on new Autodesk login system
Autodesk is working to consolidate multiple user accounts, simplify the sign in process, and provide a single User ID and Password for accessing several Autodesk web sites. To help ensure a smooth transition, we recommend that you review your current account information for accuracy, especially first name, last name, and e-mail address.
Please note: If you have multiple User IDs with the same email address and want to keep those User IDs, you’ll need to assign a unique email address for each User ID.
Sites affected:
• Autodesk Subscription
• Product Activation
• Autodesk Discussion Groups
• Autodesk University
• Autodesk Labs
• Alias Design Community
• Civil Engineering Community
• Impression Community
• Manufacturing Community
Sites affected:
• Autodesk Labs
Re: Informatio n on new Autodesk login system
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
10-02-2008 06:58 AM in reply to:
Discussion Admin
How about being able to log in and stay logged in forever? It's a small thing but a pain in the **** to have to log in everytime you start a new IE session!
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
10-03-2008 12:18 PM in reply to:
Discussion Admin
Ok, now I've got real beef with you web guys over at Autodesk. How come I can only log-in using IE. I hate using IE it is junk, is there anyway to do this in Firefox or am I out of luck?
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
10-03-2008 01:12 PM in reply to:
Discussion Admin
Firefox is my default browser and the login is working fine. Perhaps it is a configuration issue?
Mark Evans
Senior Product Manager
AEC Division, Simulation Product Line
Mark Evans
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
10-03-2008 01:19 PM in reply to:
Discussion Admin
Alright, I'm appropratly cowed. Any suggestions? I've already adjusted my pop-up filter and add blocker.
Re: Could anyone give a hand with error trap on the attribute numbering routine
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
10-11-2008 06:13 AM in reply to:
Discussion Admin
For a best undestanding, the Hallex lisp as pated from a word doc , also pasted from the vlide editor
<!--[if gte mso 9]><xml> Normal 0 21 MicrosoftInternetExplorer4 </xml><![endif]--> <!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Tabla normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} </style> <![endif]--> (defun c:numtxt ()
(initget "S LR RL TB BT")
(setq dir (getkword
(strcase
"\n Direction to Number ( S for sel / LR / RL / TB / BT ): <TB>: ")))
(if (null dir)
;;user hits enter instead of kword.
(setq DIR "TB"))
(princ "Select texts or mtexts: ")
(setq ss nil)
(while (= ss nil)
(if (setq ss (ssget (list (cons 0 "*TEXT"))))
(progn
(setq startno (getint "\Start Number?: "))
(setq inc (getint
"\Enter Increment Number? Enter for increment number: <1>: "))
(if (null inc)
(setq inc 1))
;;*******************************number by ;;selection*************************************** ***************************** **
(cond ((= dir "S")
(progn (setq ssl nil)
(setq n 0)
(repeat (sslength ss)
(setq ssl (append ssl (list (ssname ss n))))
(setq n (1+ n)))
;;repeat
) ;end progn
;;*******************************number by left to ********************************
((= dir "LR") (progn (setq ssl nil)
(setq n 0)
(setq n (1+ n)))
;;repeat
(setq ssl (vl-sort ssl
'(lambda (e1 e2)
(> (car (cdr (assoc 10 (entget e2))))
(car (cdr (assoc 10 (entget e1))))))))
;;setq
) ;end progn
;*******************************number by right to *******************
((= dir "RL")
(setq n 0)
(setq n (1+ n)))
;;repeat
'(lambda (e1 e2)
(< (car (cdr (assoc 10 (entget e2))))
(car (cdr (assoc 10 (entget e1)))))))) ;_setq
) ;_end progn
;;*********number by Top to ********
((= dir "TB") (progn (setq ssl nil)
(setq n 0)
(setq n (1+ n)))
'(lambda (e1 e2)
(> (cadr (cdr (assoc 10 (entget e1))))
(cadr (cdr (assoc 10 (entget e2)))))))) ;setq
) ;end progn
;;********************************number by bottom TO Top
((= dir "BT")
(setq n 0)
(setq n (1+ n)))
'(lambda (e1 e2)
(< (cadr (cdr (assoc 10 (entget e1))))
) ;end progn
(T nil) ;_all other cases, nothing to do
);end cond
(setq ssX (length ssl) cnt 0)
(repeat ssx
(setq ent (nth cnt ssl))
(setq elist (entget ent))
(setq newval (itoa startno))
;;changed to new value
(entmod (subst (cons 1 newval) (assoc 1 elist) elist))
(entupd ent)
(setq startno (+ startno inc))
(setq cnt (1+ cnt))) ;_end repeat
;end progn
(alert "\n No texts/mtexts selected try again")
);if
);end while
(princ) ); defun
(c:numtxt)
;|«Visual LISP© Format Options»
(120 2 50 0 nil "end of " 60 9 0 0 0 T T nil T)
;*** DO NOT add text below the comment! ***|;
(setq dir (getkword
(strcase
(if (null dir)
(setq DIR "TB"))
(setq ss nil)
(while (= ss nil)
(progn
(setq inc (getint
(if (null inc)
(setq inc 1))
(cond ((= dir "S")
(setq n 0)
(setq n (1+ n)))
;;repeat
) ;end progn
(setq n 0)
(setq n (1+ n)))
;;repeat
'(lambda (e1 e2)
;;setq
) ;end progn
((= dir "RL")
(setq n 0)
(setq n (1+ n)))
;;repeat
'(lambda (e1 e2)
) ;_end progn
(setq n 0)
(setq n (1+ n)))
'(lambda (e1 e2)
) ;end progn
((= dir "BT")
(setq n 0)
(setq n (1+ n)))
'(lambda (e1 e2)
) ;end progn
);end cond
(repeat ssx
(entupd ent)
;end progn
);if
);end while
(princ) ); defun
(c:numtxt)
