• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk FM
    Moderator
    Information on new Autodesk login system
    761 Views, 5 Replies
    08-26-2008 12:30 PM
    Autodesk is working to consolidate multiple user accounts, simplify the sign in process, and provide a single User ID and Password for accessing several Autodesk web sites. To help ensure a smooth transition, we recommend that you review your current account information for accuracy, especially first name, last name, and e-mail address.
    Please note: If you have multiple User IDs with the same email address and want to keep those User IDs, you’ll need to assign a unique email address for each User ID.
    Sites affected:
    • Autodesk Subscription
    • Product Activation
    • Autodesk Discussion Groups
    • Autodesk University
    • Autodesk Labs
    • Alias Design Community
    • Civil Engineering Community
    • Impression Community
    • Manufacturing Community
    Please use plain text.
    Valued Mentor
    TrevN
    Re: Information on new Autodesk login system
    10-02-2008 06:58 AM in reply to: Discussion Admin
    How about being able to log in and stay logged in forever? It's a small thing but a pain in the **** to have to log in everytime you start a new IE session!
    Active Member
    10-03-2008 12:18 PM in reply to: Discussion Admin
    Ok, now I've got real beef with you web guys over at Autodesk. How come I can only log-in using IE. I hate using IE it is junk, is there anyway to do this in Firefox or am I out of luck?
    Employee
    10-03-2008 01:12 PM in reply to: Discussion Admin
    Firefox is my default browser and the login is working fine. Perhaps it is a configuration issue?
    Mark Evans
    Senior Product Manager
    AEC Division, Simulation Product Line
    Active Member
    10-03-2008 01:19 PM in reply to: Discussion Admin
    Alright, I'm appropratly cowed. Any suggestions? I've already adjusted my pop-up filter and add blocker.
    Distinguished Contributor
    Re: Could anyone give a hand with error trap on the attribute numbering routine
    10-11-2008 06:13 AM in reply to: Discussion Admin
    For a best undestanding, the Hallex lisp as pated from a word doc , also pasted from the vlide editor
    <!--[if gte mso 9]><xml> Normal 0 21 MicrosoftInternetExplorer4 </xml><![endif]--> <!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Tabla normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} </style> <![endif]--> (defun c:numtxt ()
    (initget "S LR RL TB BT")
    (setq dir (getkword
    (strcase
    "\n Direction to Number ( S for sel / LR / RL / TB / BT ): <TB>: ")))
    (if (null dir)
    ;;user hits enter instead of kword.
    (setq DIR "TB"))
    (princ "Select texts or mtexts: ")
    (setq ss nil)
    (while (= ss nil)
    (if (setq ss (ssget (list (cons 0 "*TEXT"))))
    (progn
    (setq startno (getint "\Start Number?: "))
    (setq inc (getint
    "\Enter Increment Number? Enter for increment number: <1>: "))
    (if (null inc)
    (setq inc 1))
    ;;*******************************number by ;;selection******************************************************************** ** ********
    (cond ((= dir "S")
    (progn (setq ssl nil)
    (setq n 0)
    (repeat (sslength ss)
    (setq ssl (append ssl (list (ssname ss n))))
    (setq n (1+ n)))
    ;;repeat
    ) ;end progn
    ;;*******************************number by left to ********************************
    ((= dir "LR") (progn (setq ssl nil)
    (setq n 0)
    (setq n (1+ n)))
    ;;repeat
    (setq ssl (vl-sort ssl
    '(lambda (e1 e2)
    (> (car (cdr (assoc 10 (entget e2))))
    (car (cdr (assoc 10 (entget e1))))))))
    ;;setq
    ) ;end progn
    ;*******************************number by right to *******************
    ((= dir "RL")
    (setq n 0)
    (setq n (1+ n)))
    ;;repeat
    '(lambda (e1 e2)
    (< (car (cdr (assoc 10 (entget e2))))
    (car (cdr (assoc 10 (entget e1)))))))) ;_setq
    ) ;_end progn
    ;;*********number by Top to ********
    ((= dir "TB") (progn (setq ssl nil)
    (setq n 0)
    (setq n (1+ n)))
    '(lambda (e1 e2)
    (> (cadr (cdr (assoc 10 (entget e1))))
    (cadr (cdr (assoc 10 (entget e2)))))))) ;setq
    ) ;end progn
    ;;********************************number by bottom TO Top
    ((= dir "BT")
    (setq n 0)
    (setq n (1+ n)))
    '(lambda (e1 e2)
    (< (cadr (cdr (assoc 10 (entget e1))))
    ) ;end progn
    (T nil) ;_all other cases, nothing to do
    );end cond
    (setq ssX (length ssl) cnt 0)
    (repeat ssx
    (setq ent (nth cnt ssl))
    (setq elist (entget ent))
    (setq newval (itoa startno))
    ;;changed to new value
    (entmod (subst (cons 1 newval) (assoc 1 elist) elist))
    (entupd ent)
    (setq startno (+ startno inc))
    (setq cnt (1+ cnt))) ;_end repeat
    ;end progn
    (alert "\n No texts/mtexts selected try again")
    );if
    );end while
    (princ) ); defun
    (c:numtxt)
    ;|«Visual LISP© Format Options»
    (120 2 50 0 nil "end of " 60 9 0 0 0 T T nil T)
    ;*** DO NOT add text below the comment! ***|;
