• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk FM
    Member
    Re: Archibus vs FM:Systems
    10-02-2006 10:08 PM in reply to: Kevin_Van
    hi,
    does anyone knows how to get the traceability matrix for each module in archibus??
    thanx in advance=)
    Please use plain text.
    Distinguished Contributor
    10-03-2006 10:02 AM in reply to: Kevin_Van
    Steve:
    Can you tell me whether Archibus can work with Spaces and property sets attached to space objects ? right now our FM dept does polylines, and in our architectural phase we use Spaces and it would be nice to have the Archibus connected to spaces rather than polylines.
    is it possible, and how
    New Member
    11-10-2006 07:18 AM in reply to: Kevin_Van
    I like some assistance with ad hoc reporting in archibus 14 web central. I also need some assistance with importing and exporting from excel to archibus 14 web central
    Active Member
    03-23-2007 05:27 AM in reply to: Kevin_Van
    I like to believe that Autodesk FM is the right tool, however I will not put money into it unless Autodesk provides specific seminar or presentation of the System working Together with the Revit BIM System.
    The fact is that currently many of the Archibus user, if not all, are still using AutoCAD drawing files, with polyline to classify areas per BOMA, however with the New National BIM Standards, and BIM becoming the main platform for Building Design and Construction any FM solution needs to be working with a BIM Model.
    So I would like to See Autodesk FM with Autodesk Revit in action, in a case study, or a sample project shown by Autodesk.
    Employee
    03-26-2007 08:09 PM in reply to: Kevin_Van
    If you are referring to Autodesk FMDesktop, an FMDesktop specialized reseller in your area should be able to show you Revit and FMDesktop integration. I would suggest you contact Matt Davoren at CADD Microsystems in the DC area.
    Mark Evans
    Mark Evans
    Senior Product Manager
    AEC Division, Simulation Product Line
    New Member
    04-18-2007 10:14 AM in reply to: Kevin_Van
    Somebody knows where can download a demo of the Archibus?
    I looked for very pages and I did not find, needer in the official site.
    Cristine
    New Member
    01-20-2008 02:58 AM in reply to: Kevin_Van
    hello
    I am new archibusv16
    when i start the url archibus login screen it occurs an error controllerservlet is not found..anyone can help..
    thanks
