• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk FM
    New Member
    Archibus - Drawing Asset Text update question
    2007 Views, 3 Replies
    04-16-2010 05:03 AM
    We are using Archibus Overlay (DWG Editor) and I'm trying to script a command line based routine that will update the asset text in multiple drawings. I get hung up on the dialog box that pops up when envoking the ctl (catalog layer) command. It's a confirmation dialog asking "Really want to catalog all items on layer X". Is there a way to turn this off or control the ability to click 'ok' as part of the routine?
    Steve
    Please use plain text.
    *Wanderer
    Re: Archibus - Drawing Asset Text update question
    04-16-2010 06:58 AM in reply to: tarnoki
    Steve,
    I haven't actually used Archibus or the Overlay component, but, with
    AutoCAD, I'd suggest suppressing the dialog by prefacing the command
    with the minus sign (-), so you can enter text responses to the prompts.
    Would that work in your case?
    Also, associated system variables to keep in mind when automating (just
    don't forget to reset them at the end of the routine if you do use them):
    CMDDIA
    Determines whether dialog boxes open or not, during the commands that
    which use dialog boxes.
    0 dialog boxes do not appear and the required parameters are entered
    from command line
    1 dialog boxes open
    FILEDIA
    Suppresses display of file navigation dialog boxes.
    0 Does not display dialog boxes. You can still request a file dialog box
    to appear by entering a tilde (~) in response to the command's prompt.
    The same is true for AutoLISP and ADS functions.
    1 Displays dialog boxes. However, if a script or AutoLISP/ObjectARX™
    program is active, an ordinary prompt is displayed.
    I think I've read that not all dialogs can be suppressed, but, I'm not
    sure which ones can't.
    Good luck,
    Melanie Perry
    ***not all who wander are lost***
    http://augi.com/autocad
    http://MistressOfTheDorkness.blogspot.com
    On 4/16/2010 7:03 AM, tarnoki wrote:
    > Hi,
    > Thanks,
    > Steve
    New Member
    04-16-2010 08:50 AM in reply to: tarnoki
    Thanks Melanie. Unfortunately, the Archibus DWG Editor version of Autocad does not contain the CMDDIA command (theres' a bunch of cmds stripped out of this version of AutoCAD.. With FILEDIA is set, the script still invokes the dialog box. (-) in front of this particular command comes up as unknown command. My sense is this one can't be suppressed thus I was hoping for something that mimics the carriage. BTW, a space in the code (acting as carriage return) doesn't work for this script either.
    *Wanderer
    04-16-2010 08:57 AM in reply to: tarnoki
    Ah, bummer, I was afraid it wouldn't work exactly as AutoCAD would.
    Hopefully you can find an Archibus user more familiar with their
    commands, sorry and good luck!
    Melanie Perry
