• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk FM
    New Member
    BorlCand
    3ds Max Design 2011 - Approximately 3% at the end of damaged
    1291 Views, 2 Replies
    04-01-2011 06:21 AM
                            Hello!
       Downloaded Autodesk_3ds_Max_Design_2011_English_Win_32_Trial.exe, and a computer for about 4.3 minutes before the shut down ... Included again download - delighted! Download ...
        Then open, extract, and approximately 97 percent does not unpack the files (CRC does not match).
        I ask those who have unpacked the archive Autodesk_3ds_Max_Design_2011_English_Win_32_Trial.exe deflate the necessary files, and archive in the archiver. Tar.gz or other strong, so that the file was small.Total affected 50 files.
       List of files relative to the root folder is attached:
    Spoiler
    support\ADSKMaterials\CM\Protei~1.cab
    x86\max\TranslatorsCommon.cab
    x86\max\TranslatorsCommonLoc.cab
    NETVerifier\Netfx20TestApplication.exe.config
    CER\client.css
    SetupRes\max.ico
    max.ico
    Microsoft.VC90.CRT.manifest
    Microsoft.VC90.MFC.manifest
    ProdDep_UserDep.mc3
    ProdDep_UserInd.mc3
    ProdInd_UserDep.mc3
    ProdInd_UserInd.mc3
    mapfile.mlm
    x86\max\3dsMaxDesign2011_32-bit.msi
    support\backburner\2011\backburner.msi
    support\backburner\IPv6\backburner\backburner.msi
    support\backburner\backburner.msi
    SetupRes\eval.msi
    support\msxml\msxml6.msi
    support\ADSKMaterials\CM\ProteinMaterials.msi
    support\ADSKMaterials\CM\ProteinMaterialsSP1.msp
    SetupRes\deploy.mst
    SetupRes\gpo.mst
    msi\Windows6.0-KB942288-v2-ia64.msu
    msi\Windows6.0-KB942288-v2-x64.msu
    msi\Windows6.0-KB942288-v2-x86.msu
    support\backburner\IPv6\backburner\Backburner_2008 2_(IPv6Only)_Readme.pdf
    en-US\Docs\Install_3ds_Max.pdf
    en-US\Docs\Licensing_3ds_Max.pdf
    en-US\Docs\Samlite_ug.pdf
    x86\max\3dsMaxDesignConfig.pit
    x86\max\UPI\upiconfig.xml
    upiconfig.xml
    Many thanks in advance only! Do not want to re-download ...
    ______________
    Regards, Andrew.
    Please use plain text.
    New Member
    Celtemor
    Re: 3ds Max Design 2011 - Approximately 3% at the end of damaged
    11-16-2011 11:28 AM in reply to: BorlCand
    Hey, I know it's been a while since you posted this, but I'm still recieving the same problem, and do not have an answer. Someone please help...It's getting anoying downloading the same files over and over.:smileytongue:
    Distinguished Contributor
    Wanderer-MOTD
    01-16-2012 07:51 AM in reply to: Celtemor
    No one will know that here.
    You'll need to go to:
    http://forums.augi.com/forumdisplay.php?f=300
    or
    http://area.autodesk.com/forum/autodesk-3ds-max/
    Melanie Perry
    ***not all who wander are lost***
    http://AUGI.com/Surveys
    http://MistressOfTheDorkness.blogspot.com
    My defunct profiles:
    http://forums.autodesk.com/t5/user/viewprofilepage/user-id/651859
    http://forums.autodesk.com/t5/user/viewprofilepage/user-id/644095
