• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Ecotect Analysis - Desktop Tools
    New Member
    marco_baik
    problem with licensing Ecotect
    290 Views, 1 Replies
    04-14-2012 12:38 PM
    I had to reinstall ecotect after uninstalling it and when I try to submit the (student license numbers) in the new installation it tells me 'cannot license the product because there is another version of ecotect already installed' (but there isn't any). Could comeone help me?
    Please use plain text.
    TravisNave
    Re: problem with licensing Ecotect
    04-15-2012 04:08 PM in reply to: marco_baik
    It's probably stuck in the installation registry.
    To Diagnose and Fix installation problems automatically, please see the new Microsoft tool for this here:
    http://support.microsoft.com/mats/Program_Install_and_Uninstall
    For more information on the Autodesk KB Support article concerning the clean uninstall of Autdoesk products, see this link:
    http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=2887771&linkID=9240617
    For all other installation problems on Windows XP SP2 or below consider using the Microsoft Installer Clean Up Utility. For more information on this program, please my forum post here:
    http://forums.autodesk.com/t5/Installation-Licensing/Microsoft-Installer-Clean-Up-Utility-for-Add-Re...
    Travis Nave
    My Expert Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
