• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Ecotect Analysis - Desktop Tools
    New Member
    gbxml error in Ecotect 2011 while importing from Revit 2013
    1617 Views, 8 Replies
    07-05-2012 09:03 PM
    When I want to import a gbXML file in ECOTECT 2011 - (created in REVIT 2013), I get this message:
    "WARNING: IFC support is only at beta stage in this release. Whilst detailed geometry should import, ifcSpace data and complex curves may not transform correctly"
    And it does import nothing (0 spaces, 0 surfaces, 0 ...)
    What's the problem? How can this be solved?
    Thank you
    Please use plain text.
    New Member
    Re: gbxml error in Ecotect 2011 while importing from Revit 2013
    08-09-2012 06:25 AM in reply to: sharanya-te
    I have the same probelm....
    anyone knows a solution for this problem??
    please HELP me....
    New Member
    08-24-2012 01:23 AM in reply to: sharanya-te
    Same problem and the info required is urgent!
    Any solutions? Anyone...
    Member
    davidmorg
    08-27-2012 03:48 AM in reply to: sharanya-te
    I have the exact same problem. It is something to do with Revit 2013 as I never had any problems importing from Revit 2012.
    New Member
    08-29-2012 08:00 AM in reply to: sharanya-te
    I have the same problem, with revit 2013.
    With 2011 it works
    I hope some answer from somebody
    thanks
    New Member
    08-30-2012 08:50 AM in reply to: jopetit
    Member
    davidmorg
    08-30-2012 09:04 AM in reply to: dmorgan
    New Member
    10-24-2012 02:25 PM in reply to: sharanya-te
    This is still not working for me can I get a step by step instruction please? What do I do once I open the gbXML in notepad onwards? I still receive an error message in ecotect.
    Thanks!
    New Member
    10-25-2012 12:04 AM in reply to: sharanya-te
    Thanx a ton mate.. Cheers!!
