• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Ecotect Analysis - Desktop Tools
    New Member
    catherine.massart
    gbXML from ARCHICAD to ecotect
    1590 Views, 2 Replies
    02-21-2011 07:48 AM
    I start using ecotect and I'm doing some tests.
    When I want to import a gbXML file (created from ARCHICAD), I get this message:
    "WARNING: IFC support is only at beta stage in this release. Whilst detailed geometry should import, ifcSpace data and complex curves may not transform correctly"
    And it does import nothing (0 spaces, 0 surfaces, 0 ...)
    What's the problem?
    Thanks for helping
    Please use plain text.
    Active Member
    rafael.rodriguez
    Re: gbXML from ARCHICAD to ecotect
    04-28-2011 07:33 AM in reply to: catherine.massart
    I've the same problem.
    One of my costumer has ArchiCAD and would like to import IFC data into Ecotect, but the system shows that there is a beta versión. Are you going to improve this issue?
    Thanks in advance.
    Member
    08-17-2012 06:29 AM in reply to: catherine.massart
    Hi, did you find any solution to tihs problem because i am having the same problem and cant find anything about this on internet?????
    zohaib ali kalani.
