• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Ecotect Analysis - Desktop Tools
    Active Member
    Usging Ecotect to simulate artifical lighting in Radiance
    1516 Views, 2 Replies
    12-19-2010 10:04 PM
    I am having problems simulating artificial lighting in Radiance when using the calculation wizard for Radiance.
    Eventhough I at the final step specify to generate the light automatically from the pull down menu, my radiance simulations do not contain any artificial light, but only daylight.
    When simulating the artficial light levels within Ecotect everything works just fine.
    I would be very grateful for any feedback
    Please use plain text.
    Re: Using Ecotect to simulate artificial lighting in Radiance
    12-20-2010 05:02 PM in reply to: christian.bosselmann
    The light fixtures IES photometric data is not defined in radiance
    you need to convert your IES photometric data to the radiance format.
    Try using the IES2RAD utility.
    Here are a couple of links for you to check out.
    http://radsite.lbl.gov/radiance/man_html/ies2rad.1.html
    http://www.yichunhuang.com/teaching/ecotec/teaching_ecotec_other.html#ies
    Fabian
    Active Member
    12-20-2010 05:25 PM in reply to: FabianPosadas
    Thanks Fabian
    merry christmas
