Autodesk Ecotect Analysis - Desktop Tools
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Sun-Path Diagram doesn't display
- Highlight
- Email to a Friend
I am running Ecotect 2010 on a mac through parallels and am having an issue with having the sun-path diagram show up. I used the software for a while without problems, took a two month break, and when I went to use it again it is not working.
When I have a point object selected and I go to calculate--> sun path diagram... the blue dots run across the bottom of the screen but the overshadowing diagram doesn't appear. I have tried quitting ecotect and restarting, shutting down my computer and restarting, and searching all over my screen for the window. It is nowhere to be found.
Have you ever encountered this problem? Is there a way to fix this or do I just need to re-install ecotect?
Re: Sun-Path Diagram doesn't display
- Highlight
- Email to a Friend
When you push the sun path diagram window off to the side, it stays there. Search around the edges of the screen to see if the window is there somewhere. If you have 2 screens, check the other screen.
- Highlight
- Email to a Friend
Thank a lot.. that helped also me.. I begin to be worry that something happend with my software.. and sunpath window was hidden in second turned off screen... still new version of ecotect and nowhere did "kill this bug" hmm
Rich
