• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Ecotect Analysis - Desktop Tools
    New Member
    Silent Import
    257 Views, 2 Replies
    07-15-2009 02:31 AM
    I'm importing gbXML data into Ecotect via LUA "cmd("model.import C:\\Database\\Data_GH.xml")" - all works fine, however I wanted to import the data in without any dialog box showing up as I need Ecotect to run in the background. Is there any command to do this?
    Dirk
    Please use plain text.
    New Member
    Re: Silent Import
    08-07-2009 07:58 PM in reply to: DirkAnderson
    almost a month passed and not one response - great community here.
    Basically I'm writing a plugin that connects Grasshopper (Rhino Parametrics) with Ecotect to teach for a Sydney University course and since there's an annoying Ecotect dialog that pops up with gbXML import, it looks like my only option for a silent interface is to basically re-create a LUA script within Grasshopper that generates Ecotect geometry.
    If anyone else has any other interoperable tips or hints it would be much appreciated.
    Thanks.
    New Member
    2090015
    Re: Silent Import
    03-07-2012 09:07 AM in reply to: DirkAnderson
    My dear friend...I had the same problem when I was doing my master thesis. The only solutions Ißve found are:
    or you send a sendkey...to press the ok button
    or you generate the geometry directly withou imports...
    so far no other "miracle"...
