• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Ecotect Analysis - Desktop Tools
    New Member
    matthiasnave
    Shadow in Ecotect after import from ACAD geometry not right
    678 Views, 2 Replies
    01-04-2011 05:52 AM
    Hi
    I have importet a geometry from Acad (solid > explode > saveas R12.dxf > import 3D
    to Ecotect) and turned on shadows. All vertikal surfaces cast the shadow in the right
    way, but the top horizontal surfaces seem not to be there for the shadows.
    I see an open space in the shadow, but not in the geometry.
    It is as if the "roof" would not be there...
    Does someone know what to do?
    Please use plain text.
    New Member
    kapitan_sensible
    Re: Shadow in Ecotect after import from ACAD geometry not right
    01-11-2012 10:04 AM in reply to: matthiasnave
    +1
    i am also encountering this same problem. all horizontal surfaces are ignored when calculating shadows
    Valued Contributor
    arqyt
    01-15-2012 11:16 AM in reply to: kapitan_sensible
    Hei, you must verify what object type are those surfaces. Its is usual inthat conversions that many are void object and that not project shadows.
    Jose M Carralero.
    ArqyT
