• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Ecotect Analysis - Desktop Tools
    New Member
    Rhino to ecotect- SOS pls
    2388 Views, 3 Replies
    03-22-2010 02:57 AM
    I am new to ecotect. I am trying to draw a rhino model of my building to do some quick studies. The design has a lot of curves. When I import into ecotect as 3ds file, I encounter a lot of messy lines. I just wonder if there is a way to improve it. Plus, the model import appear as wireframe, how can I display it as solid?
    Thanks a lot for your help
    Please use plain text.
    Active Member
    Re: Rhino to ecotect- SOS pls
    03-24-2010 09:19 PM in reply to: janicely226
    Rhino to Ecotect is not such a good idea. My suggestion would be to use gbXML from either Revit or ArchiCAD, or as the last resort 3DS from Max where you have better control over tessellation and normals orientation.
    TZ
    New Member
    03-25-2010 09:42 AM in reply to: janicely226
    Try selecting model in Ecotect: Modify / Merge Coincident Triangles
    New Member
    04-06-2010 11:32 AM in reply to: janicely226
    To get it to not be a wireframe, try this:
    When you export , don't select the Default Export Scheme. Click Edit Schemes, then New. Create a new name and then under the General Settings tab, you want Write Surfaces and Write Meshes set to Meshes, not Curves. Click close and OK.
