• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Ecotect Analysis - Desktop Tools
    New Member
    Light Reflectance
    267 Views, 3 Replies
    06-06-2012 05:37 AM
    I use ecotect/radiance to run Daylight factors studies.
    I have a problem to set light reflectance of internal materials (floor / walls / ceiling):
    - what value should I enter ? LRV value or L* Value ?
    - Where should I enter that value: in the materials properties solar absorption (see picture 1) or in the color editor (see picture 2)
    It changes really much the results.
    Please use plain text.
    Valued Contributor
    arqyt
    Re: Light Reflectance
    06-10-2012 01:27 PM in reply to: r.cazenave
    if you click on "Highlicht: Lighting"
    In that action you can see the parameters that affect in that calculations.
    Good weekend
    Jose M Carralero.
    ArqyT
    New Member
    06-12-2012 12:41 AM in reply to: arqyt
    OK. THank you.
    But I have the LRV value of a material.
    Where do I enter it ?
    In solar absorption (1- LRV ?) or in colour (reflect.) ???
    Valued Contributor
    arqyt
    06-17-2012 11:42 AM in reply to: r.cazenave
    I don´t know what is LVR, is not similar abbreviation word in my country. But if you want to do a interior lighting analisys the main parameters are:
    - Color reflected interior
    - Specularity interior
    if you have doubt try to explore the parameters value of the material library. It is ever a good began.
    I hope help you
    Jose M Carralero.
    ArqyT
