• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Ecotect Analysis - Desktop Tools
    Valued Contributor wim
    Valued Contributor
    Importing lights into ecotect via gbxml
    819 Views, 1 Replies
    09-06-2009 01:02 PM
    When I import a gbxml file into Ecotect, the objects of type 'light' are not being imported.
    I try to export a model from revit into ecotect to be able to do lighting analyses. The lights are being exported from revit into the gbxml file, but are lost during import.
    When exporting a model form ecotect to gbxml, the lights - which I created in ecotect itself - are also not being exported.
    May I conclude that gbxml interface of ecotect does not support lights?
    Please use plain text.
    New Member
    Re: Importing lights into ecotect via gbxml
    09-19-2012 01:58 AM in reply to: wim
    hello! I met the same problem as yours. Have you solved the problem? I really have no idea about it.
