• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Ecotect Analysis - Desktop Tools
    *Expert Elite*
    aschneider1
    Accepted Solution
    Daylight Factor is soooooooooooooooo wrong!!!
    1532 Views, 6 Replies
    03-09-2011 05:03 PM
    I have been getting the craziest Daylight Factor values!  What should be 1-3% is coming out 14-54%!  Is there a setting that could have been changed somewhere to change my values?  THanks!
    Please use plain text.
    Valued Contributor
    arqyt
    Re: Daylight Factor is soooooooooooooooo wrong!!!
    03-13-2011 12:02 PM in reply to: aschneider1
    Try to verify the normal vector of the wall inside, i think it must be reverse.
    Jose M Carralero.
    ArqyT
    *Expert Elite*
    aschneider1
    03-14-2011 09:59 AM in reply to: arqyt
    I'm sorry, I am not sure where to do that...can you please point me in the right direction?
    Boesselmann
    03-16-2011 01:49 AM in reply to: aschneider1
    Dear Schneider
    from my experience the daylight simulatin within Ecotect is not very reliable, however your results are really far off.
    If you should not have done this simulation by exporting the model to Radiance try to do that.
    regards
    New Member
    tasleemkhan74
    03-17-2011 11:44 PM in reply to: Boesselmann
    I have been working in Ecotct for a long time. Acoording to my observation, if we calculate daylight factor in daysim, it gives absolutely wrong results. However, the same i have done in radiance as well to check out the result, which always give me the perfect result.
    So, I would suggeast you to use radiance to perform daylight simulation not in daysim.
    Valued Contributor
    arqyt
    03-22-2011 06:00 AM in reply to: aschneider1
    forgive the delay, Display/Surface Normals or ctrl+F9 you can see a vector that must point outside the zone. You can select the face/surface and Modify/Reverse Normals or with ctrl+R change that to the other option. With my little experience, we must review all imported model, and with overlapping windows/doors.
    Hope i´ve been helpfull. Bye
    Jose M Carralero.
    ArqyT
    *Expert Elite*
    aschneider1
    03-22-2011 10:31 AM in reply to: arqyt
    Thank you all for your responses!  After doing an Inter-Zonal Calculation, I was able to fix the problem...but I certainly appreciate all the feedback!
    Adrianna
