• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Discussion Groups Feedback
    *Expert Elite*
    Curtis_Waguespack
    Accepted Solution
    smiley faces in Code inserts
    1866 Views, 8 Replies
    06-19-2012 11:29 AM
    Is there a way to prevent the inclusion of smileys in a code insert box?
    I want this:
    But get this:
    'cut a column
    excelApp.Columns("G:G").Cut
    'insert the cut column
    excelApp.Range("D1").Insert
    'adjust column width
    excelApp.Columns("D:D").AutoFit
    'reset selected cell to A1
    excelApp.Cells(1,1).Select
    'suppress prompts (such as the compatibility checker)
    excelApp.DisplayAlerts = false
    'save the workbook
    wb.Save
     Thank You,
    Curtis
      solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
    Please use plain text.
    Jillian.Bejtlich
    Re: smiley faces in Code inserts
    06-20-2012 06:06 AM in reply to: Curtis_Waguespack
    Great question, and I'm actually not sure. Would be wonderful if we could turn the smilies off in certain boards that tend to have more programming scripts in them.
    Let me find out what we can do, and I'll get back to you.
    Thanks!
    Jillian Bejtlich
    Forum Community Manager
    Autodesk, Inc.
    Moderator
    06-20-2012 08:03 AM in reply to: Curtis_Waguespack
     There are a couple of threads in this forum on the topic and I believe it's still a individual user display preference unless there has been an update that Jillian finds for us.
    Until then it is explained how to disable viewing them in this thread.
    Discussion_Admin
    Steve_Johnson
    06-26-2012 11:11 PM in reply to: Jillian.Bejtlich
    This is one of the many things that have been complained about since the very beginning of the Lithium disaster. Eric pointed out the per-user turn-smileys-off thing fairly early on, here:
    http://forums.autodesk.com/t5/Autodesk-Discussion-Groups/How-to-prevent-smileys-from-displaying-espe...
    As we pointed out at the time, that's not a proper solution. Code should always display unformatted, period. It's not complicated. The fact that Lithium still hasn't fixed this problem 24 months later tells me that it never was, and most likely never will be, a suitable platform for technical discussion groups like these.
    Steve Johnson - blog nauseam - ClassicArray
    brian.kling
    06-27-2012 12:43 PM in reply to: Curtis_Waguespack
    Fixed, there was a setting that was released not too long ago we weren't aware of.  As long as you use the "Insert Code" button you should be all set, see your OP, smiley is gone :smileywink:
    Brian Kling
    Community Strategist
    Customer Service & Support
    Autodesk, Inc.
    Steve_Johnson
    06-27-2012 10:35 PM in reply to: brian.kling
    Jillian.Bejtlich
    06-28-2012 06:01 AM in reply to: Steve_Johnson
    Hmmm... thinking I ought to go put a sticky post up in the more programming centric boards about this new functionality, huh?
    Glad we were able to help!
    Jillian Bejtlich
    Autodesk, Inc.
    *Expert Elite*
    Curtis_Waguespack
    06-29-2012 02:39 PM in reply to: brian.kling
    If "D:D" <> "D:D" Then
    MessageBox.Show("No kudos for You!", "Autodesk Forums")
    Else If "D:D" = "D:D"
    MessageBox.Show("Thanks! :D", "Autodesk Forums")
    *Expert Elite*
    Curtis_Waguespack
    06-29-2012 02:41 PM in reply to: Jillian.Bejtlich
    A sticky probably isn't needed, since it's now working as expected without the need to do anything special.
