Autodesk Discussion Groups Feedback
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
smiley faces in Code inserts
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Is there a way to prevent the inclusion of smileys in a code insert box?
I want this:
But get this:
'cut a column
excelApp.Columns("G:G").Cut
'insert the cut column
excelApp.Range("D1").Insert
'adjust column width
excelApp.Columns("D:D").AutoFit
'reset selected cell to A1
excelApp.Cells(1,1).Select
'suppress prompts (such as the compatibility checker)
excelApp.DisplayAlerts = false
'save the workbook
wb.SaveThank You,
Curtis
Re: smiley faces in Code inserts
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Great question, and I'm actually not sure. Would be wonderful if we could turn the smilies off in certain boards that tend to have more programming scripts in them.
Let me find out what we can do, and I'll get back to you.
Thanks!
Jillian Bejtlich
Forum Community Manager
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
There are a couple of threads in this forum on the topic and I believe it's still a individual user display preference unless there has been an update that Jillian finds for us.
Until then it is explained how to disable viewing them in this thread.
Discussion_Admin
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
This is one of the many things that have been complained about since the very beginning of the Lithium disaster. Eric pointed out the per-user turn-smileys-off thing fairly early on, here:
As we pointed out at the time, that's not a proper solution. Code should always display unformatted, period. It's not complicated. The fact that Lithium still hasn't fixed this problem 24 months later tells me that it never was, and most likely never will be, a suitable platform for technical discussion groups like these.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Fixed, there was a setting that was released not too long ago we weren't aware of. As long as you use the "Insert Code" button you should be all set, see your OP, smiley is gone ![]()
Brian Kling
Community Strategist
Customer Service & Support
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hmmm... thinking I ought to go put a sticky post up in the more programming centric boards about this new functionality, huh?
Glad we were able to help!
Jillian Bejtlich
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
If "D:D" <> "D:D" Then
MessageBox.Show("No kudos for You!", "Autodesk Forums")
Else If "D:D" = "D:D"
MessageBox.Show("Thanks! :D", "Autodesk Forums")
End If
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Jillian.Bejtlich wrote:Hmmm... thinking I ought to go put a sticky post up in the more programming centric boards about this new functionality, huh?
A sticky probably isn't needed, since it's now working as expected without the need to do anything special.
