• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Discussion Groups Feedback
    New Member
    access a reply to a question
    274 Views, 3 Replies
    06-08-2012 09:44 AM
    How to i access the reply / answer to a question.
    Please use plain text.
    Charles_Shade
    Re: access a reply to a question
    06-08-2012 10:04 AM in reply to: agnesbt
    In this Forum?
    It should be on the right side of the post window in a gray box.
    Or if it is an answer to your post you should receive an email notice and the post will be at the bottom (or top) of your thread depending on your preferences
    Regards, Charles Shade            Win8 FAQ
    CSHADEDESIGN|AUTOCAD LT|LT-KB|DYNAMIC BLOCKS
      Please mark Accept as Solution if your question is answered. Kudos gladly accepted.
    06-08-2012 11:17 AM in reply to: agnesbt
    Or by "access" do you mean edit?
    If so, you can use the Options pull-down menu on the upper-right side of your post and select "Edit Reply".
    You cannot edit anyone else's posts, and there is a limited time frame before you can no longer edit it.
    Corey D.        ADSK_Logo_EE_2013.png    AutoCAD user Revit user
    ⁞|⁞ Please use the Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos functions as appropriate to further enhance the value of these forums. Thank you! ───────────────────────────────────────────────────────────────────────────────────────────
    Moderator
    06-08-2012 11:24 AM in reply to: agnesbt
    First welcome to our forums:smileyhappy:
    You can find information on getting started in the forums including how to start and reply to a thread here
    Here are a couple of other helpful links to get started
    Ground rules
    FAQ and how to forum
    Hope these help
    Discussion_Admin
