• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Discussion Groups Feedback
    *Expert Elite*
    cbenner
    Re: User Engagement Ideas?
    03-29-2012 08:19 AM in reply to: cbenner
    The main reason I bring up something like this is I've noticed that once a question is addressed by someone, (not always but sometimes true), no one else looks at the post... perhaps assuming the responder has the situation well in hand.  I thought it would be nice to be able to somehow let it be known that more help is needed.
    I agree constantly tagging the same person would make them nuts... good point.  But do you see where I'm going with this?
    ChrisB
    Please use Mark Solutions!.Accept as Solution &Give Kudos!Kudos to further enhance the value of these forums. Thank you! :smileyhappy:
    Please use plain text.
    *Expert Elite*
    03-29-2012 08:40 AM in reply to: cbenner
    I have seen some posts about installation and hardware in the Revit MEP forum, and I usually give them a link to the appropriate forum, but some of these questions might be better kept in the Revit forum. It would be useful to be able to flag it from there. I imagine tagging in this way a post would function similarly to the 'Report Inappropriate Content' function.
    So it would come down to those who would be altered to this tagging. How available do you want to be? Should a user have to volunteer as a contact to add his name to a list for this? Should the alert be PM, email, popup (kidding!)?
    Corey D.        LogoEE.png   AutoCAD user  Revit user
    ⁞|⁞ Please use the Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos functions as appropriate to further enhance the value of these forums. Thank you! ───────────────────────────────────────────────────────────────────────────────────────────
    Valued Mentor
    KerryBrown
    03-29-2012 12:59 PM in reply to: Jillian.Bejtlich
    Considering the (lack of) Help System on AutoCAD 2013 I think the changes to this place to encourage engagement will become fairly important. .... engagement of people to answer questions that is. :smileysad:
    class keyThumper<T> : Lazy<T>;      another  Swamper
    I do not endorse the social media app links below:smileyembarrassed:
    New Member
    04-11-2012 01:13 AM in reply to: Jillian.Bejtlich
    ideas on how to expand their knowledge would help some people doesn't want to share good tips and ideas that's why the forums are made for ..:catfrustrated:
    Jillian.Bejtlich
    04-11-2012 06:56 AM in reply to: HempRep
    HempRep,
    So make it easier to find getting started and learning resources, as compared to feeling inundated with high level material - right? Makes sense to me! Question is... where do you draw the line between beginning material and the more advanced stuff?
    I know we've had a lot of users voice one way or another that they come here hoping to find a manual or tutorial of sorts, so I know it's something on a lot of users' minds. I'm definitely interested in trying to figure out how to improve.
    Thank you for the feedback!
    Jillian Bejtlich
    Forum Community Manager
    Autodesk, Inc.
    *Expert Elite*
    TravisNave
    04-11-2012 09:03 AM in reply to: Jillian.Bejtlich
    There are tons of manuals and tutorials, including on YouTube.  The problem is, the customers simply do not search.  I don't know how we reinforce that.  I've created a macro full of search links and sometimes I post that to nudge them in the right direction.
    Travis Nave
    My Expert Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
    *Expert Elite*
    04-12-2012 01:50 PM in reply to: Jillian.Bejtlich
    We've all seen many new users post with a question, receive no response, and disappear forever. Being ignored is quite the deterrent for anyone. In an effort to keep them around and prevent some of these posts from slipping through the cracks, I propose an optional feature called "Mark Unanswered".
    Basically, the feature would have two independent options:
    "Highlight Unanswered".........This would very faintly shade appropriate posts (see below).
    "Unanswered to Top"............This would sort these posts before those that are not marked as such.
    How a thread is flagged as "Unanswered":
    1. Obviously, there are no replies to the post.
    2. A user flags it as such. Any user, including the OP could flag it.
    3. If the most recent post in a threat is more than 2 months newer than that previous post.
    How a thread is cleared of the "Unanswered" status:
    1. It is responded to by anyone aside from the OP.
    2. The OP clears the flag or Marks a Solution. (Maybe Super Users could as well.)
    3. A predetermined amount of time passes.
    This may improve overall responsiveness and give the Super Users a more thorough way of catching everyone that needs help. As this feature is intended to be an aid to those answering questions, this feature would be turned off by default.
    *Expert Elite*
    Cadmanto
    06-03-2012 04:56 AM in reply to: Jillian.Bejtlich
    Hi Jillian,
    My suggestion for the forum would be while users are able to deliberately select tags and bookmarks, make tags, bookmarks and ones started threads an option to select under their settings so when they select one of these categories just those items come up.  For example; a drop down that says "My bookmarks"  and JUST the threads that user has bookmarked comes up.  Not everything else.
    Hope this makes sense.
    Best Regards,
    Scott McFadden
    (2 Corinthians 5:21)
