• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Discussion Groups Feedback
    Moderator
    Re: User Engagement Ideas?
    03-23-2012 05:59 AM in reply to: Jillian.Bejtlich
    We split your post in to its own topic in the Autodesk Discussion Groups Feedback forum for active feedback on the topic.
    Customize Your Settings | Search Tips | FAQs | Fourm Feedback
    Please use plain text.
    Jillian.Bejtlich
    03-23-2012 06:25 AM in reply to: Jillian.Bejtlich
    I updated the list on Page 7 again. This thing is getting massive and I am incredibly appreciative to every user who has offered any input whatsoever. To be honest - totally blown away. :smileyvery-happy:
    Thank you!
    Jillian Bejtlich
    Forum Community Manager
    TravisNave
    03-23-2012 06:30 AM in reply to: Jillian.Bejtlich
    Charles, if you click the number of unread posts, it'll jump you to the first unread post. I discovered that recently.
    Travis Nave
    My Expert Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
    Valued Mentor
    vector2
    03-23-2012 08:49 AM in reply to: Jillian.Bejtlich
    All these Revit super users here together on this long
    thread and something historic is developing. I'm mostly
    going to be reading over all these posts and getting to
    know everyone and understand their thinking and their
    ideas. For me it means I'll be motivated to learn a lot
    more about BIM and Revit. I need this kind of motivation
    because right now I'm not all the BIM/Revit expert I can
    be.
    Steve_Johnson
    03-26-2012 01:11 AM in reply to: Charles_Shade
    Thanks Charles, mine were already set to 100 and 50, so I guess my wish is to have the posts per topic limit increased to 100 or removed altogether.
    I prefer long lines. They mean code displays properly, and that a given paragraph takes up less vertical space, meaning I need to do less scrolling.
    I would like to have the ability to use the full width of the window, rather than putting up with huge swathes of grey space either side of the content.
    Steve Johnson - blog nauseam - ClassicArray
    Valued Mentor
    vector2
    03-26-2012 07:56 AM in reply to: Steve_Johnson
    Why couldn't the reply button and stuff at the bottom be
    put to the side to take up less vertical space instead
    of text? Not sure what reading code is because I only
    know how to read words. What else is new?
    Valued Mentor
    vector2
    03-26-2012 04:28 PM in reply to: Jillian.Bejtlich
    vBulletin is far more popular than a forum like this because that's
    more for ameteurs than technical professionals like this one.
    Autodesk knows that very well and that's why we have this.
    There are plenty of ways to make a forum like this more
    intriguing, but you wouldn't want to turn it into a carnaval.
    As for altering the basic structure of a forum, that's probably
    in the program's .exe and you won't do that. Like you might
    not be able to move the reply button. But I'm sure there is
    already a setting for the column width- it's just that nobody
    ever set it.  Look at the text column width after you type in a
    google search term, I'm sure Google knows something about
    text formatting. Infact look at any book and see if the text runs
    all the way from one side of the page to the other, it don't.
    Better to varify logic than cling to a notion.
    03-27-2012 04:23 AM in reply to: vector2
    The best option would most likely be to provide each user with a "Narrow Paragraph Style" (or a more appropriate name) option under My Settings, and to leave the buttons where they are.
    Also, when users embed large images in a post (i.e. screenshot w/dual monitors), the size is reduced to fit within the margins of the post often making it impossible to make out small details. In these cases, I navigate to that user's profile page and to his image archive for a full-size image. Can clicking on an embedded image link to the full-size image as found in this archive?
    User Engagement Idea:
    New users could receive a message for the first time they get a Kudos or have authored a Solution, which would say congratulations and then explain briefly what they mean. The user will get up to two additional "Good Job!" messages at 10 and 50 unless the user opted to disable them, which would be through a "Do Not Show Me This Again" option included with each of these messages. Please comment...
    Corey D.        LogoEE.png   AutoCAD user  Revit user
    ⁞|⁞ Please use the Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos functions as appropriate to further enhance the value of these forums. Thank you! ───────────────────────────────────────────────────────────────────────────────────────────
    Jillian.Bejtlich
    03-27-2012 06:33 AM in reply to: CADastrophe
    CADastrophe,
    I like the idea on the kudos and solutions. I've been brainstorming on how we might be able to improve the initial messages users receive since right now, it's kind of feeling like a missed opportunity. :smileyfrustrated:
    What type of message would you use - pop-up? PM? E-mail?
    Thanks!
    Jillian Bejtlich
    03-27-2012 06:39 AM in reply to: Jillian.Bejtlich
    That message would not be important enough to justify bothering users through their email, and private messages often go unnoticed, especially by new users. Pop-ups would be the way to go as long as they are MINIMAL and can be suppressed. On that note, I would like to add that it needs to be slightly more apparent (visually) when you get a Private Message - That would be a great time and place for the orange color!
    And make the "New" and "Edited" text next to the subject header different colors!
