• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Discussion Groups Feedback
    Signature, Part II (Static)
    1127 Views, 6 Replies
    10-04-2012 06:51 AM
    Many users here list their software/hardware Information in their signature line so that it appears automatically in every post. The problem with this is if the information changes (which it most certainly will), all of the previous posts in which the software version (and possibly other info) was relevant becomes incorrect. I've gone back to old posts to find that someone posted a question in 2010 that was relevant to the version, but the signature in the post reported that his current version was 2013. A visitor from the future, perhaps?
    The "proper" method to report this information in through the use of macros, but that requires the user to remember to insert it for each and every post. Easy to forget, especially if one is not very used to the software (which is the case with most of the users that are asking the questions).
    I would propose that a second "signature" field be created that would be automatically added to the end of the standard signature. This field, however, should be titled "Product/Hardware Info" and the text of this field should remain static, and unchanging once added to a post. Would this even be possible with this forum software?
    (I bring this up because I saw it was posted about again recently)
    Corey D.        LogoEE.png   AutoCAD user  Revit user
    ⁞|⁞ Please use the Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos functions as appropriate to further enhance the value of these forums. Thank you! ───────────────────────────────────────────────────────────────────────────────────────────
    Please use plain text.
    pendean
    Re: Signature, Part II (Static)
    10-04-2012 02:01 PM in reply to: CADastrophe
    I like it.
    Dean Saadallah Blog | Facebook | RSS | Twitter | PINS
    TravisNave
    10-10-2012 10:02 AM in reply to: CADastrophe
    I absolutely agree to this.
    Travis Nave
    My Expert Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
    10-10-2012 01:42 PM in reply to: CADastrophe
    My issue with hardware in the signature is often there are multiples listed.
    Work PC
    bla bla lba
    Home PC
    bla bla bla
    Laptop
    bla bla bla
    Is the person who is answering the question supposed to guess which you are using?
    Charles_Shade
    10-11-2012 04:36 AM in reply to: CADastrophe
    I am one of the offenders and am considering removing that info but I don't see where it is wholly detrimental.
    If the solution is valid for the particular platform then it is valid regardless of the originators or posters updated information at a later date.
    And how often does someone disregard a Solution if the signature does not match the OP's current configuration?
    Travis asked: More Macro choices would be welcome.
    Regards, Charles Shade             Win8 FAQ
    CSHADEDESIGN|AUTOCAD LT|LT-KB|DYNAMIC BLOCKS
    Please mark Accept as Solution if your question is answered. Kudos gladly accepted.
    10-11-2012 05:38 AM in reply to: Charles_Shade
    Charles_Shade wrote:
    "And how often does someone disregard a Solution if the signature does not match the OP's current configuration?"
    I'm more wary about product version than computer stats for this, but I image it's actually pretty rare that it matters in either case at the moment. My concern lies particularly with Revit, in which the product changes somewhat significantly in each release. One example that I used in a previous post was the function "Ghost Surfaces", which no longer exists in Revit after the 2012 release. If one searches and find previous posts that include solutions that employ "Ghost Surfaces" and if any of those users have updated their signature, then Revit 2013 may be listed in the thread creating a confusing conflict.
    This is more of a desire to preserve the information and accuracy of the past posts. If information is listed in one's signature, then this information may have had an impact on the post, hence, I consider that info part of the original post.
    Jillian.Bejtlich
    10-11-2012 12:45 PM in reply to: CADastrophe
    Hmm. Good ideas. Anything that goes into a signature will continue to change as your signature evolves over time, as you've noticed. Macros have all sorts of funky behavior too.
    I'll ask our web guy the next time I have a meeting with him and find out. It would be especially nice to have a way to see what version of software a user is on, so it's a valid request.
    Thank you all!
    Jillian Bejtlich
    Forum Community Manager
