• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Discussion Groups Feedback
    **Master
    AllenJessup
    Re: Search issues?
    12-02-2011 06:33 AM in reply to: AllenJessup
    I just had to do another search. Going up one level and back to the boars seems to work every time.
    Allen
    Valued Contributor
    Search on this site does not work !
    12-07-2011 06:52 AM in reply to: wrighte
    :mansad:
    Valued Contributor
    Re: Search on this site does not work !
    12-07-2011 10:04 AM in reply to: Wheelie22
    Use google to search the forums. :smileyhappy:
    "<Search Criteria> site:<website>"
    example
    "signal arrows do not work site:forums.autodesk.com"
    Distinguished Mentor
    cbenner
    12-13-2011 10:01 AM in reply to: pjfontes
    Have had some intermittent outages of this over the last few weeks.  Doing a refresh sometimes cures it.  Also what I have seen today is that if I type in search string and hit enter key, I get nothing.  If I refresh the page, type in search string and actually use the button... it goes though.
    Please click "Accept as Solution" if this response answers your question.
    ChrisB
    "Alcohol never solved anyone's problems,... but then again niether did milk."
    ***Guru
    TravisNave
    Re: Search issues?
    01-18-2012 10:32 AM in reply to: wrighte
    Eric,
    I have found that if I put something into the search box and hit <Enter> then the search breaks every time.  It won't work even if I hit the Search button after hitting <Enter> also.  So long as I do not hit <Enter>, I can click the Search button and it works.  The only way to fix this issue temporarily is to go back a page or hit refresh (F5) and try again.
    Just an FYI.
    My Top Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Administrator | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combining .LIC Files | Search Autodesk Discussion Groups
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
    Administrator
    wrighte
    Re: Search issues?
    01-20-2012 08:58 AM in reply to: TravisNave
    We expect to have a fix for this intermittent (and annoying) issue in the next few weeks when we complete our monthly release update.
    Eric Wright
    Sr. Web Product Manager
    Web Delivery
    ***Guru
    TravisNave
    Re: Search issues?
    01-27-2012 02:38 PM in reply to: wrighte
    Eric,
    I don't know if you guys did anything, but search seems to be working as normal.  Thought I'd pass that along.
    Travis
    Administrator
    wrighte
    Re: Search issues?
    01-27-2012 03:25 PM in reply to: TravisNave
    Damn, you beat me to it - was literally just testing this to try and get it to break again :smileyhappy:
    We did deploy our monthly release update last night and it appears to have fixed the problem.  Let me know if anyone sees otherwise.
    Eric Wright
    Web Delivery
