• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Discussion Groups Feedback
    Valued Contributor
    Accepted Solution
    Problems logging in with Firefox
    333 Views, 8 Replies
    11-15-2011 09:20 AM
    Since Sunday I'm not able to log in using Firefox 8.0.  I get the following message:
    Service Unavailable
    The server is temporarily unable to service your request
    Explanation
    The server us unable to service a request because a needed resource is unavailable.
    Solution
    Please try again later
    [Back Button]
    Any ideas?
    Internet Explorer works but I keep getting pop ups directing me to the Autodesk Store or asking for feedback, etc.  Very spam like.
    John W. Mumaw
    Timber Frame Designer
    Lost Bent Woodworking & Design
    Administrator
    wrighte
    Re: Problems logging in with Firefox
    11-15-2011 10:00 AM in reply to: John.W.Mumaw
    Could you attach a few screen shots of the errors and popups  (both FF and IE)?   We did have some downtime for registration systems over the weekend, but your scenario doesn't seem like something that system maintenance would have affected.
    Eric Wright
    Sr. Web Product Manager
    Web Delivery
    Autodesk, Inc.
    Valued Contributor
    11-15-2011 10:52 AM in reply to: wrighte
    Hi Eric,
    I'm attaching two png files showing the error message in Firefox as well as a typical popup from IE.   The popups are very random.  They can occur while entering a discussion thread or while entering a discuasion group and in this case I tried entering several groups and reading a half dozen or so threads until this one popped up.  Other times, however, I can get two in a row.  They tend to vary between what you see, an invitation to fill out a survey asking how often I visit the Autodesk site, and a popup that takes me to the Autodesk store.
    Thanks for you help,
    John
    John W. Mumaw
    Administrator
    wrighte
    11-15-2011 04:04 PM in reply to: John.W.Mumaw
    Thanks. Can you also confirm how you are getting to the forums (steps to produce the error).  The URL on the error .png is from our sign in system, but not the same I see when attempting to login to the forums.  From the popup image, however it does appear (in the backgorund window for forums) that you are able to get to a logged in state for the forums?
    I don't have any expanationfor the popup.  We don't have anything in place for the forums that would prompt a popup to another site.  Very strange.
    Eric Wright
    Web Delivery
    Autodesk, Inc.
    Valued Contributor
    11-16-2011 06:14 AM in reply to: wrighte
    This morning I typed the url for Autodesk's homepage and selected discussion groups from the pulldown menu and the error appeared.  I can also navigate to the subscription center and try to login and the same error appears.
    John
    John W. Mumaw
    ***Guru
    TravisNave
    11-16-2011 07:38 AM in reply to: wrighte
    Eric,
    I was unable to automatically login from my Favorites link in IE8 this morning.  The auto-login failed with an HTTPS failure. I then logged in normally without error.
    Travis
    My Top Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Administrator | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combining .LIC Files | Search Autodesk Discussion Groups
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
    Valued Contributor
    ollikat
    11-17-2011 04:25 AM in reply to: TravisNave
    I had also same issue with Firefox. Only having screen with "Service unavailable" error when tried to browse the site.
    I removed all Autodesk coocies from browser cache and now it works!
    Valued Contributor
    11-17-2011 06:20 AM in reply to: ollikat
    Thanks, that did the trick.  I can't believe I didn't think to try that.
    John W. Mumaw
    New Member
    angellovesthedevil
    11-20-2011 02:48 AM in reply to: John.W.Mumaw
    Im using firefox, my problem is lsightly different to what the first topic is in this post but I cannot get past the re-send email activation screen. Its a miracle i found my way here. I haven't recieved an email yet and Iv'e done that about 20 times in the past hour. I wans to download this product!
    Please email me solution - if that would even work
    angelovesthedevil@hotmail.co.uk
    I want to try this maya product out get usued to it so when i go Stadfordshire in 2013 I have some knowledge of the product.
    Thanks.
