• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Discussion Groups Feedback
    *Expert Elite*
    New Feature - Search Before Post
    927 Views, 7 Replies
    11-07-2012 01:59 PM
    Seems like a very useful feature *BUT* (there's always a "but", isn't there?) it seems to search across ALL of the forums. While I was composing a message in the Inventor forum, It was suggesting some threads from the Revit and other AutoCAD forums. Now in THIS forum, it SHOULD work that way, but the search should be restricted to the proper forum.
    Corey D.        LogoEE.png   AutoCAD user  Revit user
    ⁞|⁞ Please use the Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos functions as appropriate to further enhance the value of these forums. Thank you! ───────────────────────────────────────────────────────────────────────────────────────────
    Please use plain text.
    *Expert Elite*
    Re: New Feature - Search Before Post
    11-09-2012 05:54 AM in reply to: CADastrophe
    As a momentary solution, one can identify the source forum of the suggestions by hovering over the thread in the list and referencing the link's address.
    The attached image is taken using Internet Explorer 8, which reports the address along the bottom. Hope this helps!
    brian.kling
    11-20-2012 05:18 AM in reply to: CADastrophe
    Good catch Corey - turns out with the release of this feature it is not able to filter by just the forum you are in - but Lithium is hot on the trail and will implement a fix with our upgrade which should occur by mid-December.  We'll verify when it occurs and update this post.
    Thanks for pointing it out!
    Brian Kling
    Community Strategist
    Customer Service & Support
    Autodesk, Inc.
    *Expert Elite*
    Charles_Shade
    11-20-2012 01:53 PM in reply to: brian.kling
    "Upgrade"
    Where's my seatbelt...:smileyvery-happy:
    Regards, Charles Shade             Win8 FAQ
    CSHADEDESIGN|AUTOCAD LT|LT-KB|DYNAMIC BLOCKS
    Please mark Accept as Solution if your question is answered. Kudos gladly accepted.
    *Expert Elite*
    01-25-2013 12:43 PM in reply to: brian.kling
    This still isn't working correctly, any word? This feature really doesn't do much good if users aren't provided with solutions from the proper forum. Just looking for an update on this issue.
    Jillian.Bejtlich
    01-29-2013 11:50 AM in reply to: CADastrophe
    Corey, can you give me an example of what you were searching for and in what forum? I can't seem to get it to recommend anything outside of the forum I'm in.
    Jillian Bejtlich
    Forum Community Manager
    Autodesk, Inc.
    *Expert Elite*
    01-29-2013 11:57 AM in reply to: Jillian.Bejtlich
    While composing a message in the Revit MEP forum with the subject "Title Block", the first four suggestions presented were from the Inventor forum, with the fifth hailing from the AutoCAD 2013 forum.
    Jillian.Bejtlich
    01-29-2013 12:12 PM in reply to: CADastrophe
    Ahhh... there we go. So, search suggestions from the search box work. Search suggestions from the subject box do not. Odd.
    Thanks for the clarification, Corey!
    Jillian Bejtlich
    Autodesk, Inc.
