Autodesk Discussion Groups Feedback
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Re: Known Login Issue - 404 error
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
so far I'm not seeing issues in regards of replying to posts or links to posts, etc.
I was able to access forums.autodesk.com this morning without receiving any error msg and was still signed in. However the 2nd attempt to come here less than an hour later resulted in the invalid or expired ssl cert msg.
The 3rd attempt to access the forums worked as expected and I'm still signed in and did not receive the cert msg.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
engrtech wrote:Just to put this out there, but if the forums were still accessible through a newsgroup reader, this wouldn't be a problem.
yeah, but how will they complete the "2 steps back" routine then?
1 step forward (new web-only access to forums)... 2 steps back...
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I've gotten a variety of error messages today. I've been away from these forums for quite some time due to the dreadful interface and sluggishness when they went to web-based only. I come back to post a topic, hoping to find things in better shape, only to be greeted by a different set of issues. [Roll eyes]
Service Unavailable
The server is temporarily unable to service your request.
Explanation
The server is unable to service a request because a needed resource is unavailable.
Solution
Please try again later.
[BACK BUTTON]
And another error message
Not Found
The Access Manager WebSEAL server cannot find the resource you have requested.
Explanation
The Access Manager WebSEAL server cannot find any resource matching the requested URL: /ConsolidatedLogin/html/auth.action
Solutions
If you manually entered the URL, check the accuracy of the URL.
If this appears to be a broken link, please contact the owner of the referring page:
http://forums.autodesk.com/t5/AutoCAD-2012/ExportT
[BACK BUTTON]
And another error:
There is a problem with this website's security certificate.
The security certificate presented by this website was issued for a different website's address.
Security certificate problems may indicate an attempt to fool you or intercept any data you send to the server.
We recommend that you close this webpage and do not continue to this website.
Click here to close this webpage.
Continue to this website (not recommended).
More information
If you arrived at this page by clicking a link, check the website address in the address bar to be sure that it is the address you
were expecting.
When going to a website with an address such as https://example.com, try adding the 'www' to the address, https://www.example.com.
If you choose to ignore this error and continue, do not enter private information into the website.
For more information, see "Certificate Errors" in Internet Explorer Help.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
After deploying a fix overnight, we continue to see additional errors that are intermittently preventing login to the forums (certificate errors, service unavailable messages, etc.). We’re continuing to troubleshoot this separate, but likely related issue and will continue to keep you informed through this thread.
Discussion_Admin
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
FYI, I did not receive this error when logging in today. Thanks.
My Expert Contributions to the Discussion Groups: FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!Re: Known Login Issue - 404 error
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
These were the errors I received this morning EST but have not encountered this since 10 AM this morning.
All is working well here.
CSHADEDESIGN|AUTOCAD LT|LT-KB|DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I'm happy to say that we believe the login issues have been resolved. What we discovered today is that there were multiple, unrelated issues with forums sign in (the original 404 issue and a separate issue with all the server and certificate errors that also affected sign in to other systems, including subscription. Both should now be resolved. Please let me know if you see otherwise as the new issue appeared to be intermittent (adding to the confusion and frustration).
Eric Wright
Sr. Web Product Manager
Autodesk Knowledge Network
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Noooooooooooooooooooooooooooooo!!!!!!!!!!!!!!!!! it hasn't.
I have logged in a few times and get sent to your Maya Page, Sorry not interested.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
The issue definitely is NOT fixed. I've found every time I want to post something, I can't login. The only way to login it to get my password reset each time. Doesn't matter if I restart my computer, browser or clear out my cache, seems the login is only valid for that session. Kinda amazing that an issue as basic as loginning in to a forum is taking so long to resolve.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Try deleting all your temp files and cookies from IE. That did the trick for me.
ITO - Application Management
Factory Design Suite Ultimate 2012
AutoCAD 2012 | Inventor Professional 2012 | Vault Professional 2012
