• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Discussion Groups Feedback
    bsee1
    Insert Code box doesn't load
    1252 Views, 9 Replies
    10-10-2012 07:21 AM
    The insert code button very rarely loads for me.  It pops up a small window when I click the insert code button, but no content loads in that window.  Does this happen to anyone else, and can this be addressed?
    I use Chrome stable channel and I've turned off adblock for every autodesk site.  The problem occurs even if I have no extensions loaded into Chrome.  The code button does work in Firefox however.
    Win7 x64 - 16gb ram
    i7 3610qm
    FirePro M4000
    Inventor 2013
    ETO 6.1
    Please use plain text.
    *Expert Elite*
    TravisNave
    Re: Insert Code box doesn't load
    10-10-2012 10:00 AM in reply to: bsee1
    Works on IE9.
     It's likely a browser-specific issue.  Thanks for reporting.  Hopefully it will be addressed.
    Travis Nave
    My Expert Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
    Jillian.Bejtlich
    10-11-2012 12:49 PM in reply to: bsee1
    Definitely sounds browser specific since you're seeing better behavior in Firefox, but Chrome is very much a supported browser. Let me see if I can reproduce the issue and then I'll submit to the web team.
    Thanks for letting me know!
    Jillian Bejtlich
    Forum Community Manager
    Autodesk, Inc.
    *Expert Elite*
    10-11-2012 03:37 PM in reply to: bsee1
    The Code box comes up fine for me using Chrome.
    bsee1
    10-12-2012 05:01 AM in reply to: Jeff_M
    This is what mine looks like.  This time the buttons didn't load either.  That's not quite as common, but does happen at times.
    My first thought was initially a problem with the browser/computer, but I got a new computer last week and the problem persists.
    Win7 x64 - 16gb ram
    i7 3610qm
    FirePro M4000
    Inventor 2013
    ETO 6.1
    Jillian.Bejtlich
    10-15-2012 06:30 AM in reply to: bsee1
    Hmm... behind the code box, you see where the various buttons (emoticons, hyperlink, etc.) should be? They're showing up as image icon fillers instead. Do they always do that or just when you try to load the code box?
    Jillian Bejtlich
    Autodesk, Inc.
    bsee1
    10-15-2012 06:36 AM in reply to: Jillian.Bejtlich
    Sometimes the icons load, sometimes they half load, and other times they don't load at all.  It seems to be random.  Right now about half are loading, the others aren't even showing up (not even a broken image icon, just gone).
    Win7 x64 - 16gb ram
    i7 3610qm
    FirePro M4000
    Inventor 2013
    ETO 6.1
    Jillian.Bejtlich
    10-17-2012 07:27 AM in reply to: bsee1
    So, the code box not loading is related to those buttons oddly enough. For some reason, your webpages aren't loading fully and I'm honestly not sure why (I can troubleshoot Autodesk software but browsers stump me).
    You might want to see what Chrome extensions you have running and can be turned off. Those sometimes cause a whole lot of issues. Other things to look at: security settings and cookies.
    Good luck!
    Jillian Bejtlich
    Autodesk, Inc.
    bsee1
    10-17-2012 12:16 PM in reply to: Jillian.Bejtlich
    I suppose I'll just deal with it as I have been.  More information is that this has happened on multiple computers, multiple versions of Chrome, and also happens in incognito mode(which disables all extensions).  This is not a new problem.  It's been happening for several months.
    Thanks for at least looking into it.
    Win7 x64 - 16gb ram
    i7 3610qm
    FirePro M4000
    Inventor 2013
    ETO 6.1
    Jillian.Bejtlich
    10-17-2012 01:36 PM in reply to: bsee1
    I'm really sorry I couldn't be of more help! Definitely let me know if the problem becomes more widespread (other browsers, all the time). I can't find anyone else reporting the issue so it's a tough one to figure out!
    Jillian Bejtlich
    Autodesk, Inc.
