• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Discussion Groups Feedback
    Moderator
    Alexander.Rivilis
    Accepted Solution
    Forum bug.
    1612 Views, 7 Replies
    05-04-2012 06:48 AM
    I've try to search and found some links:
    Then I clicked one of link and saw:
    What does this mean? It is look like problem only with links ended with ".../page/N", when N = 2,3,4,5, etc.
    Пожалуйста не забывайте про Утвердить в качестве решения!Утвердить в качестве решения и Give Kudos!Баллы
    Please remember to Accept Solution!Accept as Solution and Give Kudos!Kudos
    Please use plain text.
    Moderator
    Re: Forum bug.
    05-04-2012 07:01 AM in reply to: Alexander.Rivilis
    Alexander
    Where are you starting your search from?
    Discussion_Admin
    Moderator
    Alexander.Rivilis
    Re: Forum bug.
    05-04-2012 07:06 AM in reply to: Discussion_Admin
    Moderator
    Re: Forum bug.
    05-04-2012 07:34 AM in reply to: Alexander.Rivilis
    Ok managed to repeated the error.
    Try using the forum search box in the image below for searches it has better options
    There are some how to videos in the FAQ forum about using search here
    I'll escalate the other error.
    Discussion_Admin
    Moderator
    Alexander.Rivilis
    Re: Forum bug.
    05-04-2012 07:38 AM in reply to: Discussion_Admin
    I know how to search forums. It was only bug report. :smileyhappy:
    Moderator
    Re: Forum bug.
    05-04-2012 07:45 AM in reply to: Alexander.Rivilis
    Alexander,
    Just put that in there for others who might come across the the thread that do not have your working knowledge of the forums :smileyhappy:
    Discussion_Admin
    Moderator
    Alexander.Rivilis
    Re: Forum bug.
    05-04-2012 07:58 AM in reply to: Discussion_Admin
    OK! I'll assume that this topic also will be a reminder of Tony Tanzillo, who did a lot for this forum to promote AutoCAD Customization, ObjectARX, Autolisp/VisualLisp, VBA,  .NET and so on.
    Moderator
    Alexander.Rivilis
    Re: Forum bug.
    01-16-2013 10:34 PM in reply to: Alexander.Rivilis
    I would like to be reminded of this unpleasant error. For example this post has reference to: http://forums.autodesk.com/t5/Visual-LISP-AutoLISP-and-General/Navigate-Viewports/td-p/3751182/page/...
