• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Discussion Groups Feedback
    *Expert Elite*
    Charles_Shade
    Accepted Solution
    Change Solution as Accepted to the right solution
    1591 Views, 11 Replies
    10-30-2012 05:32 AM
    This thread is a good example of having the ability to change what is the Solution.
    The OP marked mine when it was indicated that the solution from Howard (hwalker) was the correct one:
    http://forums.autodesk.com/t5/AutoCAD-LT/quot-Non-Autodesk-DWG-quot-Remains-in-dwg-header-forever/m-...
    Regards, Charles Shade             Win8 FAQ
    CSHADEDESIGN|AUTOCAD LT|LT-KB|DYNAMIC BLOCKS
    Please mark Accept as Solution if your question is answered. Kudos gladly accepted.
    Please use plain text.
    brian.kling
    Re: Change Solution as Accepted to the right solution
    10-31-2012 01:01 PM in reply to: Charles_Shade
    Great suggestion Charles, check your PM queue, we are giving all the orange ranks the ability to mark/unmark Accepted Solutions for others' posts!  As you point out you can help us to ensure posts are marked correctly, both by unmarking as well as marking when appropriate (guidance provided in the PM).  This will help the entire community to find good answers more quickly.
    Brian Kling
    Community Strategist
    Brian Kling
    Customer Service & Support
    Autodesk, Inc.
    *Expert Elite*
    TravisNave
    10-31-2012 01:18 PM in reply to: brian.kling
    Brian, this is great news.  Charles, you are the man!
    When do you expect this to go into effect, Brian?
    Travis Nave
    My Expert Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
    brian.kling
    10-31-2012 01:20 PM in reply to: TravisNave
    Works right now, check your PM queue for details.  If not, then log out, log back in.
    Brian
    Brian Kling
    Autodesk, Inc.
    *Expert Elite*
    TravisNave
    10-31-2012 01:27 PM in reply to: brian.kling
    Tried logging out twice and using InPrivate browsing to eliminate the cookie situation.  Maybe it just hasn't spread to my account yet.  It's no hurry.
    Travis Nave
    *Expert Elite*
    Murph
    10-31-2012 02:36 PM in reply to: brian.kling
    Brian Kling
    Good news, that will help some of the less thread posted count groups (ie Map3d) up to date and help when users fail to mark correct solutions.
    Murph
    Supportting the troops daily.
    *Expert Elite*
    Charles_Shade
    11-01-2012 05:08 AM in reply to: Murph
    And the example thread has been cleaned up so to speak.
    Thanks!
    (On Halloween too. It's like the mad scientists have been released. :robotmad:)
    Moderator
    Alexander.Rivilis
    11-01-2012 06:12 AM in reply to: brian.kling
    brian.kling wrote:
    ... we are giving all the orange ranks the ability to mark/unmark Accepted Solutions for others' posts!...
    Hi, Brian!
    And what about giving the same ability to Moderators / International moderators?
    Пожалуйста не забывайте про Утвердить в качестве решения!Утвердить в качестве решения и Give Kudos!Баллы
    Please remember to Accept Solution!Accept as Solution and Give Kudos!Kudos
    brian.kling
    11-01-2012 06:37 AM in reply to: Alexander.Rivilis
    I'm on it!  I'll post back when done.
    Brian
    Brian Kling
    Autodesk, Inc.
    brian.kling
    11-01-2012 06:40 AM in reply to: Alexander.Rivilis
    K, moderators already had, now International Moderators do too ;-) - I'll send a PM to those groups.
    Brian
    Brian Kling
    Autodesk, Inc.
