• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Discussion Groups Feedback
    Moderator
    Alexander.Rivilis
    Accepted Solution
    Bug: receiving not subscribed emails
    612 Views, 6 Replies
    02-08-2013 04:34 AM
    I've received next e-mail:
    Hello Alexander.Rivilis,
    You have 1 update for your Autodesk Discussion Groups Subscriptions.
    Subscription to Board: AutoCAD - Русский (1 Update)
    http://forums.autodesk.com/t5/AutoCAD-%D0%A0%D1%83%D1%81%D1%81%D0%BA%D0%B8%D0%B9/bd-p/332
    There was an updated version of this Reply.
    Subject: Re: block attributes
    Author:  3wood (Distinguished Mentor)
    Date:    08-02-2013 01:54 PM
    Instead of a text with field, you need define an attribute for the second figure. After inserting the block, modify value of the second attribute with a field. Please try attached block.
    You can respond to the Reply at the following URL:
    mailto:autodesk.prod|53610efa|983ad5e1-f50c-4e4c-988e-65564b1fe3be@reply01.lithium.com?subject=Re:%20block%20attributes
    You can view the body of the Reply at the following URL:
    http://forums.autodesk.com/t5/AutoCAD-2011/block-attributes/m-p/3773123#M25926
    To manage your subscriptions or to change your subscription options.
    <...skip...>
     If you look closely you can see that topic from the wrong board.
    Пожалуйста не забывайте про Утвердить в качестве решения!Утвердить в качестве решения и Give Kudos!Баллы
    Please remember to Accept Solution!Accept as Solution and Give Kudos!Kudos
    Please use plain text.
    *Expert Elite*
    Charles_Shade
    Re: Bug: receiving not subscribed emails
    02-08-2013 05:01 AM in reply to: Alexander.Rivilis
    There has been an ongoing Spam attack over the last several days.
    Maybe this came from that.
    Autodesk is on it and will chime in if that is the case with this.
    Regards, Charles Shade             Win8 FAQ
    CSHADEDESIGN|AUTOCAD LT|LT-KB|DYNAMIC BLOCKS
    Please mark Accept as Solution if your question is answered. Kudos gladly accepted.
    Moderator
    Alexander.Rivilis
    02-08-2013 05:08 AM in reply to: Charles_Shade
    Hi, Charles!
    It is not look like SPAM attack. I really subscripted with this board:
    But topic: http://forums.autodesk.com/t5/AutoCAD-2011/block-attributes/m-p/3773123#M25926 is not from that board, but from board: http://forums.autodesk.com/t5/AutoCAD-2011/bd-p/407
    This is very strange.
    Moderator
    02-08-2013 05:57 AM in reply to: Alexander.Rivilis
    Alexander,
    This is a known issue currently under investigation.
    Discussion_Admin
    Moderator
    Alexander.Rivilis
    02-08-2013 06:24 AM in reply to: Discussion_Admin
    Discussion_Admin wrote:
    Alexander,
    Discussion_Admin
    Thanks!
    I then ask my colleagues, who have the same problem, do not write about it. :-)
    Moderator
    02-08-2013 02:50 PM in reply to: Alexander.Rivilis
    The issue has been isolated and a fix is being put in place.
    Let us know if you keep getting these.
    Discussion_Admin
    Moderator
    Alexander.Rivilis
    02-13-2013 02:42 AM in reply to: Discussion_Admin
    Look like fixed - no new not subscribed emails. Thanks!
