• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Discussion Groups Feedback
    Valued Contributor
    amason43
    Accept as Solution
    475 Views, 8 Replies
    06-18-2010 09:23 AM
    We need to be allowed to accept more than one post as a solution.
    Anthony Mason - CAD/BIM Manager
    Nichols Melburg & Rossetto Architects + Engineers
    Blog: Daily Occurrence
    AutoCAD Architecture 2008 SP2 / Revit Architecture 2011
    Microsoft Windows XP SP3 / Google Chrome
    Please use plain text.
    Administrator
    wrighte
    Re: Accept as Solution
    06-18-2010 02:58 PM in reply to: amason43
    It's intended to be used to select the "best" contributing post to the solution.  One approach for a case where there is more than one would be to reply confirming what specifically helped and mark your reply as the accepted item.
    Eric Wright
    Sr. Web Product Manager
    Autodesk Knowledge Network
    Autodesk, Inc.
    06-21-2010 06:07 AM in reply to: wrighte
    Which is likely to never happen with most posts.  I'm thinking the
    majority of people will identify the first reply that works for them
    as the "best" solution and never review the thread again.
    Valued Contributor
    amason43
    06-21-2010 08:06 AM in reply to: Jason.Piercey
    Especially since a lot of the things I've needed help with have involved multiple steps.  Example:
    Hey, anyone know how I can 'abc'?
    Yeah, try putting the 'L' in the 'c'.
    Ok, I did that, and it mixed it up.
    Oops.  That should be 'lowercase l' and 'uppercase C'.
    Ohhh, nice, now I just really wish it would 'y'.
    It will, if you 'x' the 't' and '.' the 'i'.
    So, which one of these is the "best" solution?
    Points for solving:
    l=
    C=
    Distinguished Contributor
    ACADuser
    06-21-2010 10:52 AM in reply to: amason43
    While I agree that there may be more than one post contributing to the solution.  Even if a post had a link to the supposed solution I would still read the entire thread.  A recent example that I ran across is in this post;
    http://forums.autodesk.com/t5/AutoCAD-Civil-3D/Importing-LandXML-File-Scaling-Issue/m-p/2699071#M133...
    Post #4 is relevant and may be part of the solution for someone else experiencing the problem.
    I would rather have a good search engine rather than "solution" flags.  Maybe they should enable the "kudos" feature that way you know if the accepted "solution" was presented by someone having a good reputation - j/k.
    ACADuser
    Dell Precision T5500 Workstation
    Windows XP Professional SP3
    Dual Quad Core Intel Xeon Processors E5540 2.53GHz,8M L3,5.8GT/s,turbo
    4GB, DDR3 Memory, 1066MHz, ECC (4 DIMMS)
    1.5GB NVIDIA Quadro FX 4800, DUAL MON, 2DP & 1DVI
    160GB, 3.0Gb/s, 16MB Data Burst Cache,SATA2,10K RPM Hard Drive
    16XDVD AND 16XDVD+/-RW
    Valued Contributor
    amason43
    06-21-2010 10:55 AM in reply to: ACADuser
    You may be kidding, but I don't think that's too bad of an idea.
    Active Contributor
    Ken.Krupa
    06-28-2010 07:29 AM in reply to: wrighte
    It would be good if the OP were able to change the "accepted solution" designation to another post - if a much better solution were later found and posted.
    That happened to me, where a solution I accepted turned out to be half-baked, and I posted a better one myself. As is, anyone searching for the same problem will be lead straight to the half-baked solution and might never see the better one several posts further down.
    Ken Krupa
    Krupa CADD Solutions
    http://www.krupacadd.com
    Board Manager
    06-28-2010 07:50 AM in reply to: Ken.Krupa
    Ken,
    You can do that.
    1. Open the message you selected as the "accepted solution".
    2. Click on the "Options" drop down and choose "Not the solution" and confirm it.
    3. Accept a new message as the solution.
    I just tried it out in the Test forums
    Active Contributor
    Ken.Krupa
    06-28-2010 07:59 AM in reply to: matt.smith
    matt.smith wrote:
    Ken,
    You can do that.
    OK - Thank you!
    Ken Krupa
